LACP : Cisco ASA 5515 & Switch ProCurve 2920
romainamardeil
I've two ASAs 5515 connected in failover Active/Stand by (on Gi0/5)
My two ASAs are connected to two Switch ProCurve 2920 to have HA if something happens. So I plug something like that (don't pay attention to the arrows) :
So one the ASA, I created a Port-Channel like that :
interface GigabitEthernet0/0
nameif outside
security-level 0
ip address 192.168.1.3 255.255.255.0 standby 192.168.1.4
interface GigabitEthernet0/1
speed 1000
duplex full
channel-group 1 mode passive
no nameif
no security-level
no ip address
interface GigabitEthernet0/2
speed 1000
duplex full
no nameif
no security-level
no ip address
interface Port-channel1.1
vlan 1
nameif inside
security-level 100
ip address 192.168.8.1 255.255.255.0 standby 192.168.8.2
interface Port-channel1.10
vlan 10
nameif guest
security-level 50
ip address 172.16.100.2 255.255.255.224 standby 172.16.100.3
interface Port-channel1.16
vlan 16
nameif dmz
security-level 50
ip address 192.168.16.1 255.255.255.0 standby 192.168.16.2
On the switch, I created a trunk LACP capable with the port 1 and 2 on each switch, force the speed to 1000 and put the port un full duplex mode.
BUT this is not working... I tried many things and I can't make it work.
In this configuration, I can't ping anything between my ASA and my Switch (or any object connected). Here what I get on my ASA :
Channel group 1
                             LACP port     Admin     Oper    Port        Port
Port      Flags   State      Priority      Key       Key     Number      State
Gi0/2     SP      not-bndl   32768         0x1       0x1     0x3         0xc
Gi0/1     FP      not-bndl   32768         0x1       0x1     0x2         0x6
And on the Switchs :
PORT   LACP      TRUNK   PORT     LACP      LACP
NUMB   ENABLED   GROUP   STATUS   PARTNER   STATUS
1      Active    trk1    Broken   Yes       Failure
2      Active    trk1    Broken   Yes       Failure
If I change the Cisco interface to LACP mode On, I can ping the switch from the ASA but nothing other objects conneted on the switch. If I look at the statut of LACP on the switch I see this :
1      Active    trk1    Up       No        Success
2      Active    trk1    Up       No        Success
I don't have any clue on what's going on so If someone have any idea and help me on this, it would be great !
Feel free to ask me anything if you need any more information !
Thanks a lot !
Peter Paluch
Romain,
I am afraid this won't work. All physical links in an EtherChannel must be connected between the same pair of devices. In your case, this requirement is not met, so an EtherChannel can not be deployed successfully.
I do not actually see a need or a sensible use for EtherChannels in your network, though. What were you trying to accomplish?
Best regards,
Peter
Hi Peter,
Thank you for helping me.
Basically, I would like to be able to "loose a switch" and be sure that the other switch can still work and contact the firewalls.
I would like to distribute all my Vlans through the trunk (and IP associated) and be sure that the primary ASA can be reached by the same IP on the two switch.
I'm trying to make something redundant.
Do you think it's possible ?
Have a nice day
Romain
