Showing results forĀ
Search instead forĀ
Did you mean:Ā
Parser View
kamrannaseem
Level 3
Level 3
Hi All,
Just need to confirm If the IOS version  c2960-lanbasek9-mz.122-35.SE5.bin  supports parser view ?
any help will be much appriciated.
many thanks.
Favaloro.
Level 3
Level 3
Apparently not.
Checked the "Cisco command lookup" and the "aaa new-model" command is not supported, therefore, it doesn't support views.
Favaloro.
Level 3
Level 3
Apparently not.
johnlloyd_13
Level 11
Level 11
i agree with favaloro. role-based access control (RBAC) doesn't show up on this platform.
it does show on ISR routers and some modular switches (4500 and 6500).
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Thanks everyone.
