12-30-2019 12:12 AM
Hello @All
I was wondering if there is a possibility to find the partner port like it is possible when using pagp (please see below output)
SW-1#sh pagp neighbor
Flags: S - Device is sending Slow hello. C - Device is in Consistent state.
A - Device is in Auto mode. P - Device learns on physical port.
Channel group 1 neighbors
Partner Partner Partner Partner Group
Port Name Device ID Port Age Flags Cap.
Et0/0 SW-2 aabb.cc80.0200 Et1/0 6s SC 10001
Et0/1 SW-2 aabb.cc80.0200 Et1/1 2s SC 10001
thanks and please excuse my newbie question
12-30-2019 01:31 AM
the command 'show lacp neighbor' should work in the same way, provided (obviously) that the port channel is up and active:
S1#sh lacp neighbor
Flags: S - Device is requesting Slow LACPDUs
F - Device is requesting Fast LACPDUs
A - Device is in Active mode P - Device is in Passive mode
Partner's information:
LACP port Admin Oper Port Port
Port Flags Priority Dev ID Age key Key Number State
Gi1/0 SA 32768 0cd5.2e9f.a800 1s 0x0 0x1 0x101 0x3D
Gi1/1 SA 32768 0cd5.2e9f.a800 2s 0x0 0x1 0x102 0x3D
S1#
12-30-2019 07:23 AM
Hey Georg,
the port information is not from the other switch, that port listing is from the switch you are running the command.
What I was looking was for a command that is showing the partner's ports that are members in the channel.
12-30-2019 08:08 AM
if I change the lacp priority on the neighboring switch, it is reflected in the output, so I think the output is from the neighbor/partner:
S1#sh lacp neighbor detail
Port System ID Port Number Age Flags
Gi1/0 32768,0cd5.2ead.5300 0x101 5s SA
LACP Partner Partner Partner
Port Priority Oper Key Port State
65535 0x1 0x3D
Port State Flags Decode:
Activity: Timeout: Aggregation: Synchronization:
Active Long Yes Yes
Collecting: Distributing: Defaulted: Expired:
Yes Yes No No
Gi1/1 32768,0cd5.2ead.5300 0x102 3s SA
32768 0x1 0x3D
Active Long Yes Yes
Yes Yes No No
S2
interface GigabitEthernet1/0
media-type rj45
negotiation auto
lacp port-priority 65535
channel-group 1 mode active
