LACP Port Priority
RAGHU N
Hello Guys,
I have a small doubt about Lacp Port priorit values, as some doc says it ranges from 0 - 65535, but some says about 1 - 65535. setting lacp port priority is 0 is considerd to be better than 1 or , 0 means not available for selection like OSPF priority 0 ??
Thanks alot
Raghu Ram .
Reza Sharifi
0 is the highest priority and 32768 is the lowest priority. The higher the number the lower the priority.
http://www.cisco.com/en/US/docs/optical/cpt/r9_3/command/reference/cpt93_cr_chapter_01000.html#wp6855662460
Reza Sharifi
