Not able to get outside of network on wireless - 1811W Router
rrealy
I have configured router to issue ip's on two vlan's. Vlan1 works fine, vlan2 is for the wirless issues the correct ip but not will not
let me go the internet.
Any help will be greatly appreciated.
Current configuration : 9574 bytes
! Last configuration change at 17:43:57 PCTime Fri Aug 30 2013
! NVRAM config last updated at 15:36:03 PCTime Fri Aug 30 2013 by patrick
version 12.4
hostname St.Patricks
boot-start-marker
boot-end-marker
logging message-counter syslog
no logging buffered
enable secret 5 $1$lvNA$wGnkzv7kjLmif0RNDxf2g0
no aaa new-model
clock timezone PCTime -6
clock summer-time PCTime date Apr 6 2003 2:00 Oct 26 2003 2:00
crypto pki trustpoint TP-self-signed-3607837666
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3607837666
revocation-check none
rsakeypair TP-self-signed-3607837666
crypto pki certificate chain TP-self-signed-3607837666
certificate self-signed 01
30820243 308201AC A0030201 02020101 300D0609 2A864886 F70D0101 04050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 33363037 38333736 3636301E 170D3133 30383239 30363232
34395A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 36303738
33373636 3630819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100E525 0425ECCD 2F904636 B21AF280 AD7993E4 8F79564C 6203B366 E769FAF5
62DACE0A 40CFD386 0F5BD78F FE7C6A7C EACC4A3C 3F84A48C AC7D3280 9FF029BE
D5BA4E83 00F7BD4B 11984721 76F5CCDF D03E6CD7 84195C8F 73D770C8 99734F0D
4F583941 0BE9FD8D 87F3D876 FFDB0588 2BECA057 79DA62D2 AC47D3ED 6AE5C7F4
B3AB0203 010001A3 6B306930 0F060355 1D130101 FF040530 030101FF 30160603
551D1104 0F300D82 0B53742E 50617472 69636B73 301F0603 551D2304 18301680
146385C7 4B02E815 B28909F2 2A604395 37FB3F60 21301D06 03551D0E 04160414
6385C74B 02E815B2 8909F22A 60439537 FB3F6021 300D0609 2A864886 F70D0101
04050003 81810067 7A20CF98 7D7FAC17 A5B73A4A 00BEAE11 3BFFF9BC 1A74E61A
E7DC833C FDBA0BB8 A0F74011 C3B1F3AA 0CF39238 66A9AF5F EB62E3C3 D92A4289
E6000537 D253E03F A1B95F7C A545EC84 14724057 E72DAEE2 568A7B40 174FEB03
1373CFAE 4BEC84B1 794E3E1B D56E2DDC DD2B1162 7B0A782C A4D2391E 83DA63D6
4CD7029D B9F668
       quit
dot11 syslog
dot11 vlan-name Wireless_VLAN vlan 2
dot11 ssid St.Patricks_WiFi
vlan 2
authentication open
authentication key-management wpa
guest-mode
mbssid guest-mode
infrastructure-ssid optional
wpa-psk ascii 0 patrick1
ip source-route
ip dhcp excluded-address 10.10.10.1 10.10.10.99
ip dhcp excluded-address 10.10.11.1 10.10.11.99
ip dhcp pool DHCP_POOL
   import all
   network 10.10.10.0 255.255.255.0
   dns-server 208.67.222.123 208.67.220.123
   default-router 10.10.10.1
   domain-name St.Patricks
ip dhcp pool WireLess_Pool
   import all
   network 10.10.11.0 255.255.255.0
   domain-name St.Patricks_Wireless
ip cef
ip name-server 208.67.222.123
ip name-server 208.67.220.123
no ipv6 cef
username patrick privilege 15 secret 5 $1$MLJt$jLLnyQkm61ukzlwxHB/7f0
archive
log config
hidekeys
class-map type inspect match-any SDM_BOOTPC
match access-group name SDM_BOOTPC
class-map type inspect match-any SDM_HTTPS
match access-group name SDM_HTTPS
class-map type inspect match-any SDM_SSH
match access-group name SDM_SSH
class-map type inspect match-any SDM_SHELL
match access-group name SDM_SHELL
class-map type inspect match-any sdm-cls-access
match class-map SDM_HTTPS
match class-map SDM_SSH
match class-map SDM_SHELL
class-map type inspect match-any SDM_DHCP_CLIENT_PT
match class-map SDM_BOOTPC
class-map type inspect match-any ccp-skinny-inspect
match protocol skinny
class-map type inspect match-any sdm-cls-bootps
match protocol bootps
class-map type inspect match-any ccp-cls-insp-traffic
match protocol cuseeme
match protocol dns
match protocol ftp
match protocol https
match protocol icmp
match protocol imap
match protocol pop3
match protocol netshow
match protocol shell
match protocol realmedia
match protocol rtsp
match protocol smtp extended
match protocol sql-net
match protocol streamworks
match protocol tftp
match protocol vdolive
match protocol tcp
match protocol udp
class-map type inspect match-all ccp-insp-traffic
match class-map ccp-cls-insp-traffic
class-map type inspect match-any ccp-h323nxg-inspect
match protocol h323-nxg
class-map type inspect match-any ccp-cls-icmp-access
match protocol icmp
match protocol tcp
match protocol udp
class-map type inspect match-any ccp-h225ras-inspect
match protocol h225ras
class-map type inspect match-any ccp-h323annexe-inspect
match protocol h323-annexe
class-map type inspect match-all sdm-access
match class-map sdm-cls-access
match access-group 101
class-map type inspect match-any ccp-h323-inspect
match protocol h323
class-map type inspect match-all ccp-icmp-access
match class-map ccp-cls-icmp-access
class-map type inspect match-all ccp-invalid-src
match access-group 100
class-map type inspect match-any ccp-sip-inspect
match protocol sip
class-map type inspect match-all ccp-protocol-http
match protocol http
policy-map type inspect ccp-permit-icmpreply
class type inspect ccp-icmp-access
inspect
class class-default
pass
policy-map type inspect ccp-inspect
class type inspect ccp-invalid-src
drop log
class type inspect ccp-protocol-http
inspect
class type inspect ccp-insp-traffic
inspect
class type inspect ccp-sip-inspect
inspect
class type inspect ccp-h323-inspect
inspect
class type inspect ccp-h323annexe-inspect
inspect
class type inspect ccp-h225ras-inspect
inspect
class type inspect ccp-h323nxg-inspect
inspect
class type inspect ccp-skinny-inspect
inspect
class class-default
drop
zone security in-zone
zone security out-zone
zone-pair security ccp-zp-self-out source self destination out-zone
service-policy type inspect ccp-permit-icmpreply
zone-pair security ccp-zp-in-out source in-zone destination out-zone
service-policy type inspect ccp-inspect
zone-pair security ccp-zp-out-self source out-zone destination self
bridge irb
interface FastEthernet0
description WAN$FW_OUTSIDE$
ip address dhcp
ip nat outside
ip virtual-reassembly
zone-member security out-zone
duplex auto
speed auto
interface FastEthernet1
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface FastEthernet9
interface Dot11Radio0
no ip address
no dot11 extension aironet
encryption vlan 2 mode ciphers tkip
broadcast-key vlan 2 change 30
mbssid
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Dot11Radio0.2
encapsulation dot1Q 2 native
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio1
no ip address
speed basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0
station-role root
interface Dot11Radio1.2
bridge-group 1
interface Vlan1
description $FW_INSIDE$
ip address 10.10.10.1 255.255.255.0
ip nat inside
zone-member security in-zone
interface Vlan2
ip address 10.10.11.1 255.255.255.0
bridge-group 1
interface Async1
no ip address
encapsulation slip
interface BVI1
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface FastEthernet0 overload
ip access-list extended SDM_BOOTPC
remark CCP_ACL Category=0
permit udp any any eq bootpc
ip access-list extended SDM_HTTPS
remark CCP_ACL Category=1
permit tcp any any eq 443
ip access-list extended SDM_SHELL
permit tcp any any eq cmd
ip access-list extended SDM_SSH
permit tcp any any eq 22
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 10.10.10.0 0.0.0.255
access-list 1 remark Wireless
access-list 1 permit 10.10.11.0 0.0.0.255
access-list 100 remark CCP_ACL Category=128
access-list 100 permit ip host 255.255.255.255 any
access-list 100 permit ip 127.0.0.0 0.255.255.255 any
access-list 101 remark CCP_ACL Category=128
access-list 101 permit ip any any
control-plane
bridge 1 protocol ieee
bridge 1 route ip
banner motd ^C
YOU ARE NO AUTHORIZED -------- SEE ADMINISTRATOR
^C
alias exec s show ip int br
alias exec sr show run
line con 0
exec-timeout 0 0
logging synchronous
line 1
modem InOut
stopbits 1
speed 115200
flowcontrol hardware
line aux 0
line vty 0 4
login
transport input telnet ssh
end
Elton Babcock
Things looks a little weird with the VLAN 2 interface having an IP address. Once you create the BVI interface that is where all of the layer 3 stuff should go.
I would so try adding IP NAT inside to the BVI interface.
Elton
Elton Babcock
Elton
I failed to do the IP NAT ...
Thansk!
