LACP Protocol Configuration between 2 Remotly connected Switch
ItransformTech
Guys,
Just check looking below topology, pls suggest if we can configure LACP Port channel between 2 remotely connected switch.
these location connected via ISP in between,LACP Protocol Configuration between 2 Remotly connected Switch
you run l2vpn over ISP Core
MHM
Giuseppe Larosa
Hello @ItransformTech ,
in order to achieve what you want the service provider needs to provide you two p2p EomPLS pseudowires or equivalent configuration performed with l2VPN.
You need two ELINE in Metro ethernet forum terminology so that LACP frames are carried over it and delivered to only one remote link.
Hope to help
Giuseppe
