LACP to switch and router
sebastien3
Level 4
Level 4
I want to set up an LACP between an ASR1000 and a 3750X.
ASR = LACP Active
3750X = LACP Passive
ASR1000 :
interface Port-channel1
 description *** PO1 to 3750X ***
ip address 10.0.0.1 255.255.255.252 no negotiation auto ! interface GigabitEthernet0/0/0 description *** LACP *** no ip address no negotiation auto channel-group 1 mode active ! interface GigabitEthernet0/0/1 description *** LACP *** no ip address no negotiation auto channel-group 1 mode active !
3750X :
 description *** LACP to ASR1001 ***
 switchport access vlan 10
 switchport mode access
interface GigabitEthernet1/0/7
 channel-protocol lacp
 channel-group 1 mode passive
interface GigabitEthernet1/0/8
ASR#sh etherchannel load-balancing
EtherChannel Load-Balancing Method:
Global LB Method: flow-based
LB Algo type: Source Destination IP
  Port-Channel:                       LB Method
    Port-channel1                   :  flow-based (Source Destination IP)
    Port-channel2                   :  flow-based (Source Destination IP)
3750X#sh etherchannel load-balance
EtherChannel Load-Balancing Configuration:
        src-mac
EtherChannel Load-Balancing Addresses Used Per-Protocol:
Non-IP: Source MAC address
  IPv4: Source MAC address
  IPv6: Source MAC address
On ASR and 3750 I specified port-channel load-balance src-dst-ip but on the ASR but it does not work, it stays in mode Source Destination IP.
What do you think is the problem ?
Many thank !
10 Replies 10
Hello
Many thank !
You have a L3 PC on the rtr and L2 PC on the switch, this wont work.
Change the switch to a L3 PC.
conf t
no int port 1
default interface gig1/0/7
default interface gig1/0/8
int port 1
ip address x.x.x.x.
no shut
int range interface gig1/0/7 -8
shut
no switchport
Kind Regards
Paul
Hi @paul driver
My switch have a VLAN, I don't use no switchport...
Hello
I understand that but i would say you cannot really establish a L2 port-channel with a L3 PC, So for this specific connection to work between your rtr and switch i would suggest make the PC on the switch a L3 connection as such it will then require its own ip addressing.
Kind Regards
Paul
Hello @sebastien3 ,
in your current setup the switch will use a different load balancing algorythm based on source MAC address if all the traffic is sourced by the switch SVI in vlan 10, then  a single member link will be used in the direction switch to ASR regardless of source IP and destination IP address.
You can have IP connectivty between a L3 port channel and an SVI via a L2 port channel, but load balancing results can be poor as explained above based on the output of your first post.
Probably with a L3 port channel you could be able to use a different load balancing on the C3750 too getting more fair use of member links.
Hope to help
Giuseppe
Thank you @Giuseppe Larosa
My need is to have redundancy between the switch and the router with a higher bandwidth if possible due to the use of two ports on each device.
The only solution that I found on the redundancy between the two devices is to make the following configuration.
I don't think the traffic is sending 50/50 on each port but rather a port that is always active. I am wrong ??
ASR1000
 no ip address
 negotiation auto
interface Port-channel1.99
 encapsulation dot1Q 99
 ip address 10.0.99.1 255.255.255.252
 no ip redirects
 no ip unreachables
 no ip proxy-arp
interface Port-channel1.100
 encapsulation dot1Q 100
 ip address 10.0.100.1 255.255.255.252
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 description *** EIGRPP IPv4 ***
 no ip address
 no negotiation auto
 channel-group 1
 no ip address
 negotiation auto
 channel-group 1
3750X
interface Port-channel10
 switchport trunk allowed vlan 99,100
 switchport mode trunk
 description *** EIGRP ASR ***
 channel-group 10 mode on
Hello @sebastien3 ,
unfortunately even using two different SVI vlan 99 and vlan 100 they will use the same source MAC address by default.
However, you should be able to manually change the MAC address used on one of the two SVI
do
show int vlan 99
show int vlan 100
then take note of the listed MAC address and change the last bit in the less significant byte (rightmost)
int vlan 100
mac 00AA.BBBB.CCCD
in this way you should achieve load balancing with two different source MAC addresses on the two ECMP vlan 99, vlan 100 in the direction switch to ASR.
Hope to help
Giuseppe
Hello @Giuseppe Larosa
Thank for your help !
Not stupid this trick to change the MAC, but I have a question !
I don't have a VLAN interface on the switch and therefore no IP. The switch is only in access mode for VLANs.
Do I have to change the MAC on the Port-channel of the router or can I only create a vlan99 & vlan100 interface on the switch with only the MAC without @ IP?
I recall (?) the 3750 offers multiple (global) Etherchannel hashing choices. If so, look for one that uses src-dest-x. (Even with a L2 Etherchannel, you should also still be able to use a src-dest-IP option [often a better choice than -MAC], if offered.)
Hello @Joseph W. Doherty
Here is what can be configured on a 3750X :
3750X12S(config)#port-channel load-balance ?
  dst-ip       Dst IP Addr
  dst-mac      Dst Mac Addr
  src-dst-ip   Src XOR Dst IP Addr
  src-dst-mac  Src XOR Dst Mac Addr
  src-ip       Src IP Addr
  src-mac      Src Mac Addr
On my 3750X I have configured src-dst-ip (port-channel load-balance src-dst-ip)
"On my 3750X I have configured src-dst-ip (port-channel load-balance src-dst-ip)"
Yup, that's (again) often the best choice.
BTW, changing the load balancing algorithm might (?) require a reload for it to actually change.
