05-05-2009 06:47 AM - edited 03-06-2019 05:32 AM
Hi all, when talking about LACP, i believe this is a dynamic protocol, if I put say 4 ports in active state, its this as good as forcing them to multlink, like a fixed etherchannel config? so if I do show etherchannel summary, they will all show as up? or will they have to still negotiate with the other side ?
05-05-2009 07:42 AM
LACP is a negotiated etherchannel. If it negotiates correctly all ports will show as up in the port channel.
05-06-2009 12:53 AM
So what will happen if I put them in active mode ? is this not fixing the grou at one end? or do they stll need to receive a pdu from the other side to become part of the lacp group ?
05-06-2009 09:35 AM
Active means it will use LACP as the bundling protocol . You can either have active on both ends or active on one end and passive on the other .
to hardcode the channel it would be channel-group X mode on
05-12-2009 02:48 AM
Hi there
so, when we hardcode it, will the ports show up as always active even if not negoiated? like a fixed etherchnnel ?
