LAG link down when adding interface to channel (Packet Tracer)
Ergo0ne
Hi everyone,
I'am experiencing some issues trying to add a new FastEthernet interface to a channel group already configured.
My configuration on both switches is simple :
  • ACCESS on Vlan 10 or 20 for the PC 'Fa 0/3-4'
  • Port-channel
    • Trunk
    • Vlan allowed 10 & 20
  • switch to switch IF 'Fa 01-3'configured with only
    channel-group 1 mode active
  • Channel group active links : Fa 01-2 (Fa 05 no wired)
interface Port-channel1
 switchport trunk allowed vlan 10,20
 switchport mode trunk
interface FastEthernet0/1
interface FastEthernet0/2
interface FastEthernet0/3
 switchport access vlan 10
interface FastEthernet0/4
 switchport access vlan 20
interface FastEthernet0/5
The issue is, when i connect the Fa 0/5 IF's between switches i have at least 4 packet losses between the PC's before the channel group IF get back to green is up again.
Is it an issue that is related to Packet Tracer or will i experience the same issue with physical cisco 2960 ?
Please feel free if something has to be done to limite this delay or delete it !
Thank you.
Jaderson Pessoa
Dear, something doenst work properly on packet tracer, try make it using GNS3.
thanks in advance.
Mask as helpful or solved if it help you.
Jaderson Pessoa
*** Rate All Helpful Responses ***
