Nexus 31108TCV - WS-C3850-24XS-S
Francho02
Components:
-Nexus 31108TCV
-CVR-QSF-10G
-GLC-EX-SMD
--- WS-C3850-24XS-S
---GLC-EX-SMD
We have a trunk connection with another Cisco WS-C3850-24XS-S and Nexus 31108TCV equipment, where we also have sfp GLC-EX-SMD
The FO physical connection section measures 12 Kms away.
Some tests were performed with OTDR to measure losses in the FO at both ends. I have -18 dbm
According to Cisco I need to reach at least -13dbm for the Nexus 31108TCV
6 Replies 6
Reza Sharifi
Is your fiber single mode?
Yes, my  Fiber is Single Mode..
Ok, so do the ports come up on both switches when you connect the fiber?
In theory, yes, but it does not show UP in the interface.
I was looking according to cisco specifications in the TMG, with the components but the only one to find is N3K-C31108PC-V and not N3K-C31108TC-V
https://tmgmatrix.cisco.com/home
--N3K-C31108TC-V
--CVR-QSFP-10G
--GLC-EX-SMD
I see. Couldn't be 100% sure but I would think it should work on both models since both of these switches are part of the same platform. It is just One is copper and the other one is SFP+. Also, you may want to run it by your SE or your Cisco rep, so they can research it internally.  Cisco's documentation is not always very clear.
Today, in a last consultation, we tried to lift the link with a 10G long-distance sftp and the interface could not be lifted either.
I had the following record:
SW-SWITCH# sh interface ethernet 1/49 transceiver details
Ethernet1/49
transceiver is present
type is 10Gbase-ER
name is CISCO-OPNEXT,INC
part number is TRS7050EN-S103
revision is 0012
serial number is ONT174700QA
nominal bitrate is 10300 MBit/sec
Link length supported for 9/125um fiber is 40 km
cisco id is 3
cisco extended id number is 4
cisco part number is 10-2531-02
cisco product id is SFP-10G-ER
cisco vendor id is V02
SFP Detail Diagnostics Information (internal calibration)
Current Alarms Warnings
Measurement High Low High Low
Temperature 31.95 C 75.00 C -5.00 C 70.00 C 0.00 C
Voltage 3.26 V 3.63 V 2.97 V 3.46 V 3.13 V
Current 50.49 mA 120.00 mA 20.00 mA 112.00 mA 24.00 mA
Tx Power 0.45 dBm 6.99 dBm -8.72 dBm 3.99 dBm -4.71 dBm
Rx Power -11.93 dBm 1.99 dBm -20.00 dBm -1.00 dBm -15.85 dBm
Transmit Fault Count = 0
Note: ++ high-alarm; + high-warning; -- low-alarm; - low-warning
SW-SWITCH(config-if)# speed 10000
Speed is 10G, but the port doesn't support this speed
SW-SWITCH(config-if)# exit
