LAN Base IOS 4948-10GE
yassine-m
What's the major difference between the LAN Base IOS and the IP Base IOS for the 4948-10GE switch.
This reference WS-C4948-10GE is shipped with optional software image, what's that means ?
Br
jliscano
I just did a comparison between both the latest images 12.2.52-SG(ED). Here they are:
Features Unique to IP Base IOS w/o Crypto Image:
Call Home
Config Change Tracking Identifier
EIGRP Stub Routing
Embedded Event Manager (EEM) 2.0
FHRP - VRF Aware VRRP
FHRP - HSRP - Hot Standby Router Protocol V2
IP Enhanced IGRP Route Authentication
IPv6 Multicast
IPv6 Multicast: MLD Access Group
IPv6 Multicast: Multicast Listener Discovery (MLD) Protocol, Versions 1 and 2
IPv6 Multicast: PIM Accept Register
IPv6 Multicast: PIM Embedded RP Support
IPv6 Multicast: PIM Source-Specific Multicast (PIM-SSM)
IPv6 Multicast: PIM Sparse Mode (PIM-SM)
IPv6 Multicast: Routable Address Hello Option
IPv6 Multicast: RPF Flooding of Bootstrap Router (BSR) Packets
IPv6 Multicast: Scope Boundaries
Rapid-Per-VLAN-Spanning Tree (Rapid-PVST)
Smart Port
Virtual Router Redundancy Protocol (VRRP)
Features Unique to LAN Base IOS w/o Crypto Image:
IP SLAs - DLSW+ Operation
Jerry Ye
Hi Yassine,
LAN Base IOS means it only has L2 features, such as VTP, STP, RSTP, etc.
IP Base IOS means it has basic L3 features, like static route, RIP, etc.
Optional software are the additional features like SSH, where it consider crypto image.
You can check out this slide for additional information:
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps8802/ps5460/prod_presentation0900aecd803e36bb.pdf
HTH,
jerry
