DHCP relay question
miclacs13
Hey guys,
I am not sure if I am missing something but, do you have to enable service DHCP if your router is NOT functioning as a DHCP server but only as a DHCP relay?
xcz504d1114
Level 4
Level 4
Nope, all you need is an ip helper-address on your client side interface :)
HTH,
Craig
Jerry Ye
Hi Michael,
All you have to do is put ip helper-address in the interface.
HTH,
jerry
Yeah, that is what I've thought. Thanks to all who responded and double-confirming it.
Mike
