LAN Base Routing SDM
kamarul4619
Does WS-2960X-24TS-L running on LAN Base Routing SDM can support HSRP?
T.Q
Mark Malone
Yes lanbase supports hsrp on 2960s have it running on some of our switches here
Mark,
T.Q for the answer. however, what about on 2960X series?
its not a hardware based feature its software so once your 2960x has lanbase it will support it
you can check exactly what features are supported per IOS using the software navigator
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
