LAN fast download SLOW upload ???
rico_hao40
I have a server and a client both directily to 3550.
Server port hardcode to 100/full
Client port is auto.
Problem is download from server to clietn is fast. But upload file from client to server is extreamly slow.
Client is a Gigabit card, and I tried to setting auto and later 100/full but same result.
I remember I have the similar issue before when I using a certain Gigabit LAN card I had speed problems with server.
Is cisco switch does not work properly with some LAN card ???
xcz504d1114
Level 4
Level 4
Are you getting any errors on either port? Is the server using teamed NIC's or just one NIC?
m_zabetian
Always if you configure port with speed/duplex configure other side too. You should not configure one side auto and other side manual
