LAN Problem
muraripadhan
Level 3
Level 3
Hi Dears
there are two departments one is IT and another is HR
From IT to HR connected through single mode ofc and using SFP module.
In HR depatrment there are two switch
SW1 ip  is 192.168.1.10/24
SW2 ip is 192.168.1.11/24
(Here SW1 is connected with IT core and SW2 is connected with SW1 using UTP patch cord)
In IT
Core switch ip is 192.168.1.2/24
and Router ID is 192.168.1.1/24
Problem No-1
When I trying to SW1  ping 192.168.1.10 at that time it shows "request timeout" & "host Unreachable"
but at the same time when i trying to sw2 192.168.1.11 its pinging
Please tell me the problem and give me the solution ?
Problem No-2
When i pinging to my core switch at that time its pinging but when i trying to pinging to my router at that time is also showing "request timeout" & "host unreachable" but its working fine.
10 Replies 10
Diana Karolina Rojas
In problem 1: From which device or devices are you trying to do the ping to your SWs?
In problem 2: From which device or devices are you trying to do the ping to your Core and Router?
How are your devices connected to each others? Can you provide the topology?
---Do not forget to rate useful answers---
I am trying to ping from my computer.
My pc ip is 192.168.1.100/24 (this is my Network admin PC)
My topology is
Router--->Core---->SW1----->SW2 (all are cisco switch)
Router Model is 3700
Core is 4006
SW1 is SG500-28 port
SW2 is SF300
Router and Core are connected using Cat6 cable
Core and SW1 are connected using Single mode SFP module
SW1 and SW2 are connected using cat6 cable.
Router is connected to other division (My location is Hyderabad and other location is Bangalore)
There is no fault to connect to HYDERABAD to BANGALORE
Are you using cross cable to connect between sw1 and sw2?
Yes sir
Are Your vlan up in layer 2 and layer 3? in all the switches including the core?
yes sir
Hello
Sounds like you have a flat network and your router is performing the L3 routing?
If so then all switches need to have ip routing disabled and default-gateway pointing to 192.168.1.1 (RTR)
Switches:
no ip routing
ip default-gateway 192.168.1.1
res
Paul
Kind Regards
Paul
On recent models you can use straight cables to connect the switches, could you please provide the model of your switches: core, sw1 and 2, and router.
I think the topology is:
Router - Core Switch - SW1 - SW2
Thank you
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Router model is 3000 series
Core is 4006
SW1 is sg500-28
SW2 is SF300
Sir topology is
Router- core-SW1- SW2
Thank you
The gateway for the vlans should be configured on the Core 4006 for example:
vlan 10-11,100
ip routing
interface vlan 10
ip add 192.168.10.1 255.255.255.0
no shutdown
interface vlan 11
ip add 192.168.11.1 255.255.255.0
no shutdown
interface vlan 100
description MANAGEMENT-DEVICES
ip add 192.168.100.1 255.255.255.0
no shutdown
- Now the trunk
interface g1/24
switchport
switchport mode trunk
no shutdown
- SW1 and SW2
Should have the required vlans and using trunks interface between then and the SW1 with Core.
- Router and Core
Should use a routing protocol to create an adjacency and enable the communication.
Now, may I know why the SW2 is not connected to the Core directly instead of cascade it?
