LAN Routing Problem
jrgates
I have 2 4506's and a 3845 MPLS router. I'm attaching the diagram. I'm trying to figure out why when I do a traceroute from a remote site it is going to the 10.1.1.5 to the 10.1.1.4.
Here's the EIGRP info for one of our networks.
Routing entry for 10.90.6.0/24
Known via "eigrp 201", distance 90, metric 3072, type internal
Redistributing via eigrp 201, bgp 64512
Advertised by bgp 64512
Last update from 10.1.1.5 on GigabitEthernet0/0, 22:03:43 ago
Routing Descriptor Blocks:
* 10.1.1.5, from 10.1.1.5, 22:03:43 ago, via GigabitEthernet0/0
Route metric is 3072, traffic share count is 1
Total delay is 20 microseconds, minimum bandwidth is 1000000 Kbit
Reliability 255/255, minimum MTU 1500 bytes
Loading 1/255, Hops 1
10.1.1.4, from 10.1.1.4, 22:03:43 ago, via GigabitEthernet0/0
Loading 5/255, Hops 1
Not sure why the Loading is higher for the 10.1.1.4 route.
Jobe
Funnily enough i was about to suggest you connect up the 3825 to 10.1.1.5 directly for added redundancy.
In answer to your question no it won't because you can't have the 2 interfaces on the 3825 in the same subnet, it's not allowed.
The recommended way would be to use 2 P2P routed links from the 3825 to the 4500's ie.
3825
int gi0/1 (connected to 10.1.1.5 switch)
ip address 192.168.5.1 255.255.255.252
int gi0/2 (connected to 10.1.1.4 switch)
ip address 192.168.5.5 255.255.255.252
4506 (10.1.1.5 switch)
int gi0/1
no switchport
ip address 192.168.5.2 255.255.255.252
4506 (10.1.1.4 switch)
int gi0/1
no switchport
ip address 192.168.5.6 255.255.255.252
then the 3825 will have 2 equal cost paths to all networks on the 4500 but the next-hops will be different.
Jon
8 Replies 8
jrgates
Here's the configs from the 4506's and 3845.
10.1.1.4
router eigrp 201
redistribute static
network 10.0.0.0
network 192.168.1.0
no auto-summary
eigrp router-id 220.220.220.220
10.1.1.5
router eigrp 201
redistribute static
network 10.0.0.0
network 192.168.1.0
no auto-summary
10.1.1.3
router eigrp 201
redistribute static
redistribute bgp 64512
network 10.0.0.0
network 192.168.1.0
default-metric 10000 100 255 100 1500
no auto-summary
Jon Marshall
Jobe
"I'm trying to figure out why when I do a traceroute from a remote site it is going to the 10.1.1.5 to the 10.1.1.4."
Could you clarify what you mean by that ?
Also can you repost the .jpg - have a look it only has an IP address in it.
Jon
Ok I've reposted the .jpg.
It looks like my traffic instead of hitting a server say hanging off the 10.1.1.4 switch is bouncing to 10.1.1.5 first and then back to 10.1.1.4. The drawing should help.
Jobe
The traceroute - can you post it ?
Also, in your first post you show a routing entry for 10.90.6.0/24. Is this from the 3825 ?
Bear in mind that if there are 2 equal cost paths to a destination a traceroute will use them both.
Jon
Sure here you. The 4506's are using HSRP also.
Yes the traceroute is from the 3845.
Tracing the route to ho1mail.ad.burns-wilcox.com (10.90.6.55)
1 10.1.1.5 0 msec
10.1.1.4 4 msec
10.1.1.5 4 msec
2 ho1mail.ad.burns-wilcox.com (10.90.6.55) 0 msec 4 msec 0 msec
BW-3845-HQ#sh ip route 10.90.6.0
Last update from 10.1.1.5 on GigabitEthernet0/0, 1d00h ago
* 10.1.1.5, from 10.1.1.5, 1d00h ago, via GigabitEthernet0/0
10.1.1.4, from 10.1.1.4, 1d00h ago, via GigabitEthernet0/0
Jobe
It's not bouncing over to 10.1.1.5 and then back again. If it was then you would see it as different numbered entries ie.
1 10.1.1.4
2 10.1.1.5
3 10.1.1.4
4 ho1mail.ad.burns-wilcox.com (10.90.6.55) 0 msec 4 msec 0 msec
but your entry is
1 1 10.1.1.5 0 msec
10.1.1.4 4 msec
10.1.1.5 4 msec
ie it is only 2 hops. If there are 2 equal cost paths to a destination in the routing table then when you do a traceroute it will always send packets to both.
It's nothing to worry about.
Jon
Jon that does make sense. Would the traceroute still look the same if I added the second NIC to the 3845 and hook it to 10.1.1.5? Then I'll have complete redundancy.
Jobe
3825
int gi0/1
no switchport
int gi0/1
no switchport
Jon
