08-31-2007 04:16 AM - edited 03-05-2019 06:13 PM
What switch and router are best to use for an organization with 200 PCs?
Solved! Go to Solution.
08-31-2007 05:21 AM
I think 2800 is good enough because it gives good edge of scalability.
200 User traffic it can be support.
If you would expand your network.. it support higher no of rate Serial connections as weel as highr no of VPN connections.
Dharmesh Purohit
08-31-2007 04:23 AM
3750's switch and 2800 series router.
Router
http://www.cisco.com/en/US/products/ps5854/index.html
Switch
http://www.cisco.com/en/US/products/hw/switches/ps5023/index.html
~JG
08-31-2007 05:21 AM
Dharmesh Purohit
08-31-2007 07:21 AM
Hey,
Thank buddy... I got badge change by your last Vote.
Thanks...
Dharmesh
