LAN Transceiver
amitkaushik24
We have one central location. Here I am putting 2960 series switch. We have two more buldings one is 600mtr, second is 700mtr away from central location. I wants to connect both the location by multimode fiber LX.
I required external transceiver to connect both site by 2960 series switch. (Which convert multimode fiber LX to ethernet. I have two gigabit port at central location switch) I am unable to find out external transceiver for 2960 series switch. pls suggest me soon.
Regds
AK
ahmednaas
Level 8
Level 8
You'll have to get a third party media converter such as:
http://www.fiberdyne.com/products/sfp_gigabit.html#standalone
Check the specs for max. distance.
h_hammad
Level 2
Level 2
Hi , I don't see reason to have transceiver , if the fiber cable is multimode ST and the switch port SC , then you need St-SC converter .
Thx
Some of the models in the series have only copper ports.
