Last usable firmware for WS-3750G-24PS? Newer images will not load
neulingermst
What is the latest firmware that you can load on this device:
lab-cisco3750g-apt#show hardware
Cisco IOS Software, C3750 Software (C3750-I9-M), Experimental Version 12.2(20050726:174023) [astrived-wrigley 285]
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Fri 26-Aug-05 09:41 by astrived
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: HULC Boot Loader (C3750-HBOOT-M), Version 12.2 [sabe-bootldr 103]
lab-cisco3750g-apt uptime is 22 hours, 41 minutes
System restarted at 20:51:40 UTC Wed Dec 13 2017
System image file is "flash:/boot"
cisco WS-C3750G-24PS (PowerPC405) processor with 118784K/12280K bytes of memory.
Last reset from power-on
Target IOS Version 12.2(25)SE
23 Virtual Ethernet interfaces
28 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:13:5F:xx:xx:xx
Motherboard serial number : CSJ0910xxxx
Model number : WRIGLEY
Hardware Board Revision Number : 0x01
Switch Ports Model SW Version SW Image
* 1 28 WS-C3750G-24PS 12.2(20050726:174023) C3750-I9-M
Release notes seem to make it sound like 12.2(55) will work, but I've tried both SE12 and SE1, and both of them result in "Hardware not supported by firmware" during attempted boot?
Does anyone know the latest version that will actually work?
(Yes, I realize this is an ancient piece of junk, it's in an old test lab.)
7 Replies 7
Leo Laohoo
Where did you get this unit? This is running an EXPERIMENTAL IOS. I'm not even sure if the hardware is part of the development team.
Console into the switch and boot the IOS you want. We want to see what the switch is doing.
Original source unknown - company has had this device for years.
Here's what I see booting 12.2(55)SE1 for example:
<Dec/13 11:47 am>Base ethernet MAC Address: 00:13:5f:0c:xx:xx
<Dec/13 11:47 am>Xmodem file system is available.
<Dec/13 11:47 am>The password-recovery mechanism is enabled.
<Dec/13 11:47 am>Initializing Flash...
<Dec/13 11:47 am>flashfs[0]: 9 files, 1 directories
<Dec/13 11:47 am>flashfs[0]: 0 orphaned files, 0 orphaned directories
<Dec/13 11:47 am>flashfs[0]: Total bytes: 32514048
<Dec/13 11:47 am>flashfs[0]: Bytes used: 18018816
<Dec/13 11:47 am>flashfs[0]: Bytes available: 14495232
<Dec/13 11:47 am>flashfs[0]: flashfs fsck took 9 seconds.
<Dec/13 11:47 am>...done Initializing Flash.
<Dec/13 11:47 am>Boot Sector Filesystem (bs) installed, fsid: 3
<Dec/13 11:47 am>done.
<Dec/13 11:47 am>Loading "flash:/c3750-ipbasek9-mz.122-55.SE1.bin"...@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@<Dec/13 11:47 am>@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@<Dec/13 11:47 am>@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
<Dec/13 11:47 am>File "flash:/c3750-ipbasek9-mz.122-55.SE1.bin" uncompressed and installed, entry point: 0x1000000
<Dec/13 11:47 am>executing...
<Dec/13 11:47 am>Error: hardware not supported by firmware.
<Dec/13 11:47 am>       Try loading newer software instead.
<Dec/13 11:48 am>       System Resetting...
Here's what I get with the version that's on the device now (that does work):
<Dec/13 11:51 am>Loading "flash:/boot"...@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@<Dec/13 11:51 am>@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
<Dec/13 11:51 am>File "flash:/boot" uncompressed and installed, entry point: 0x3000
<Dec/13 11:51 am>executing...
<Dec/13 11:51 am>
<Dec/13 11:51 am>              Restricted Rights Legend
<Dec/13 11:51 am>Use, duplication, or disclosure by the Government is
<Dec/13 11:51 am>subject to restrictions as set forth in subparagraph
<Dec/13 11:51 am>(c) of the Commercial Computer Software - Restricted
<Dec/13 11:51 am>Rights clause at FAR sec. 52.227-19 and subparagraph
<Dec/13 11:51 am>(c) (1) (ii) of the Rights in Technical Data and Computer
<Dec/13 11:51 am>Software clause at DFARS sec. 252.227-7013.
<Dec/13 11:51 am>           cisco Systems, Inc.
<Dec/13 11:51 am>           170 West Tasman Drive
<Dec/13 11:51 am>           San Jose, California 95134-1706
<Dec/13 11:51 am>Cisco IOS Software, C3750 Software (C3750-I9-M), Experimental Version 12.2(20050726:174023) [astrived-wrigley 285]
<Dec/13 11:51 am>Copyright (c) 1986-2005 by Cisco Systems, Inc.
<Dec/13 11:51 am>Compiled Fri 26-Aug-05 09:41 by astrived
<Dec/13 11:51 am>Image text-base: 0x00003000, data-base: 0x00C3E7EC
<Dec/13 11:51 am>Initializing flashfs...
<Dec/13 11:51 am>
<Dec/13 11:51 am>flashfs[1]: 9 files, 1 directories
<Dec/13 11:51 am>flashfs[1]: 0 orphaned files, 0 orphaned directories
<Dec/13 11:51 am>flashfs[1]: Total bytes: 32514048
<Dec/13 11:51 am>flashfs[1]: Bytes used: 18018816
<Dec/13 11:51 am>flashfs[1]: Bytes available: 14495232
<Dec/13 11:51 am>flashfs[1]: flashfs fsck took 2 seconds.
<Dec/13 11:51 am>flashfs[1]: Initialization complete....done Initializing flashfs.
<Dec/13 11:51 am>
<Dec/13 11:51 am>front_end/ (directory)
<Dec/13 11:51 am>extracting front_end/fe_type_1 (34696 bytes)
<Dec/13 11:51 am>extracting front_end/front_end_ucode_info (43 bytes)
<Dec/13 11:51 am>extracting ucode_info (76 bytes)
<Dec/13 11:51 am>POST: CPU MIC register Tests : Begin
<Dec/13 11:51 am>POST: CPU MIC register Tests : End, Status Passed
<Dec/13 11:51 am>Yeti Test CLI init........
<Dec/13 11:51 am>Retry(PortASICs Detected 0,configured 7)
<Dec/13 11:51 am>(# of PortASICs Detected 7,configured 7)....done
<Dec/13 11:51 am>POST: PortASIC Memory Tests : Begin
<Dec/13 11:51 am>POST: PortASIC Memory Tests : End, Status Passed
<Dec/13 11:51 am>
<Dec/13 11:51 am>POST: CPU MIC PortASIC interface Loopback Tests : Begin
<Dec/13 11:51 am>POST: CPU MIC PortASIC interface Loopback Tests : End, Status Passed
<Dec/13 11:51 am>POST: PortASIC RingLoopback Tests : Begin
<Dec/13 11:51 am>POST: PortASIC RingLoopback Tests : End, Status Passed
<Dec/13 11:51 am>
<Dec/13 11:52 am>Waiting for Stack Master Election (around 30 seconds)...
<Dec/13 11:52 am>POST: PortASIC CAM Subsystem Tests : Begin
<Dec/13 11:52 am>POST: PortASIC CAM Subsystem Tests : End, Status Passed
<Dec/13 11:53 am>
<Dec/13 11:53 am>POST: No Cable found on stack port 1
<Dec/13 11:53 am>POST: No Cable found on stack port 2
<Dec/13 11:53 am>POST: PortASIC Stack Port Loopback Tests : Begin
<Dec/13 11:53 am>POST: PortASIC Stack Port Loopback Tests : End, Status Passed
<Dec/13 11:53 am>POST: PortASIC Port Loopback Tests : Begin
<Dec/13 11:53 am>POST: PortASIC Port Loopback Tests : End, Status Passed
<Dec/13 11:53 am>
<Dec/13 11:53 am>Election Complete
<Dec/13 11:53 am>Switch 1 booting as Master
<Dec/13 11:53 am>Waiting for Port download...Complete
<Dec/13 11:53 am>cisco WS-C3750G-24PS (PowerPC405) processor with 118784K/12280K bytes of memory.
<Dec/13 11:53 am>Last reset from power-on
<Dec/13 11:53 am>Target IOS Version 12.2(25)SE
<Dec/13 11:53 am>1 Virtual Ethernet interface
<Dec/13 11:53 am>28 Gigabit Ethernet interfaces
<Dec/13 11:53 am>The password-recovery mechanism is enabled.
<Dec/13 11:53 am>512K bytes of flash-simulated non-volatile configuration memory.
<Dec/13 11:53 am>Base ethernet MAC Address       : 00:13:5F:xx:xx:xx
<Dec/13 11:53 am>Motherboard serial number       : CSJ0910xxxx
<Dec/13 11:53 am>Model number                    : WRIGLEY
<Dec/13 11:53 am>Hardware Board Revision Number  : 0x01
<Dec/13 11:53 am>Switch   Ports  Model              SW Version              SW Image
<Dec/13 11:53 am>------   -----  -----              ----------              ----------
<Dec/13 11:53 am>*    1   28     WS-C3750G-24PS     12.2(20050726:174023)   C3750-I9-M
Hmmmm ... Can you try other versions other than 12.2(55)SE1? Try 12.2(55)SE10 perhaps?
I've tried SE12 - same result as SE1. (That's what I tried first, since it was listed as the recommended version in the
download portal.) When that didn't work, I rolled back to SE1 to see if that made any difference.
I did specifically see the notation in the 12.2(58) documentation saying that 12.2(55) was the last version to support the WS-3750G-24PS - which is why I was very confused when neither of the 12.2(55)'s worked.
I think the hardware is "locked down".
It's distinctly possible we got this directly from Cisco (as a vendor providing them service, not as a customer) years back, so that's a possibility.
What I'm taking from your responses is - this is not a normal case. I'll head down that path.
