Not asking for enable password on cisco switch
Haider Raza
i configured enable password on my cisco switch, while logging into the switch is not asking and it goes to the # mode directly.
Here i attached screen shot of config so Kindly help.
6 Replies 6
marce1000
    - Depends on the assigned privilege-level, of the user , you logon with.
M.
how i solve the problem , please let me know, what should i keep the standard configuration to avoid this issue ...
fotismark
Hi friend,
You have configured passwords for console, vty lines etc. So when you connect to the switch through a console does it request for password? It should. But for the Enable to request password, go to Conf t terminal, and Enable password, or enable secret. Difference are secret is encrypted password is not. then exit and try again
Hello
All depend on your access credential and how it configured.
It could be you have login disabled on these lines or you have assigned privilege level or both  and using  local database username/password
If you want to use a generic priv exec password with a local username then:
Username STAN secret fred
enable secret  letmein
line con 0
login local
line vty 0 4
login local
res
Paul
Kind Regards
Paul
Thanks for your support
