Latency issue in Local LAN
I am facing latency issue in my local lan from last 2 days .
when i am trying to ping from system to VLAN  ip ( Default Gateway ) there is more latency arround 150ms.
Can any body help on this .
Thanks ,
Eshwar
jawad-mukhtar
Level 4
Level 4
Check CPU Usage.
Chec Physical Connectivity.
Check Port Speed and Duplex Settings
Check Spanning Tree
Jawad
Thanks ..
CPU and Memory is ok ..
Connectivity is also ok......
Are u receieving any errors on interfaces.
Jawad
No...
It is not happening continiusaly ..
Today was etting 140 Ms from my system ...
