Latency of Catalyst 2960-X
f.sanzes1
Greetings,
In my company, we are studying to replace a switch in an office where latency is a very important characteristic.
We are doubting whether to place a Catalyst 2960-X or a Nexus 3000 (since these are the two switches we already have and can place in that office).
Searching through cisco.com I have found the latency of the Nexus 3000 (here: http://www.cisco.com/c/en/us/products/switches/nexus-3000-series-switches/models-comparison.html) but sadly I am not able to find such information about the Catalyst 2960-X.
Does anyone know what the latency of this type of switches is?
Thanks in advance.
7 Replies 7
Mark Malone
3000 series are specially built low latency data centre switches that can be used in stock exchanges and other high end markets that cannot have any latency  , the 2960 would not come anywhere near it and is not built for that  , its a low end user access switch  , the most you will find regarding what it can do is the pps per second compared to other 2960s
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-2960-x-series-switches/data_sheet_c78-728232.html
Table 12.     Cisco Catalyst 2960-X Series Forwarding Performance
Forwarding Rate: 64-Byte L3 Packets
Catalyst 2960-XFamily
Cisco Catalyst 2960X-48FPD-L
130.9 Mpps
Cisco Catalyst 2960X-48LPD-L
130.9 Mpps
Cisco Catalyst 2960X-24PD-L
95.2 Mpps
Cisco Catalyst 2960X-48TD-L
130.9 Mpps
Cisco Catalyst 2960X-24TD-L
95.2 Mpps
Cisco Catalyst 2960X-48FPS-L
107.1 Mpps
Cisco Catalyst 2960X-48LPS-L
107.1 Mpps
Cisco Catalyst 2960X-24PS-L
71.4 Mpps
Cisco Catalyst 2960X-24PSQ-L
71.4 Mpps
Cisco Catalyst 2960X-48TS-L
107.1 Mpps
Cisco Catalyst 2960X-24TS-L
71.4 Mpps
Cisco Catalyst 2960X-48TS-LL
104.2 Mpps
Cisco Catalyst 2960X-24TS-LL
68.5 Mpps
Catalyst 2960-XR Family
Cisco Catalyst 2960XR-48FPD-I
130.9 Mpps
Cisco Catalyst 2960XR-48LPD-I
130.9 Mpps
Cisco Catalyst 2960XR-24PD-I
95.2 Mpps
Cisco Catalyst 2960XR-48TD-I
130.9 Mpps
Cisco Catalyst 2960XR-24TD-I
95.2 Mpps
Cisco Catalyst 2960XR-48FPS-I
107.1 Mpps
Cisco Catalyst 2960XR-48LPS-I
107.1 Mpps
Cisco Catalyst 2960XR-24PS-I
71.4 Mpps
Cisco Catalyst 2960XR-48TS-I
107.1 Mpps
Cisco Catalyst 2960XR-24TS-I
71.4 Mpps
Thank you Mark
Hello again,
Do you know where I can find the forwarding performance table of the Nexus 3000?
Thanks in advance.
Fran
Yes check these links , each model can vary so make sure you check the one you have specifically
http://www.cisco.com/c/en/us/products/switches/nexus-3000-series-switches/datasheet-listing.html
Performance
  5.12 Tbps switching capacity
  Forwarding rate up to 3.8 bpps
  Line-rate traffic throughput (both Layer 2 and 3) on all ports
  Configurable maximum transmission unit (MTU) of up to 9216 bytes (jumbo frames)
Is that correct?
The slowest 2960X has a forwarding rate of 68.5 Mpps, which is way faster than the 3.8bpps of the Nexus 3000
thats 3.8 billion packets per second , bit quicker id say than 2960 :)
oh okay yes I understand now, I read bits per second, my bad.
Thank you very much.
