12-10-2014 02:57 PM - edited 03-07-2019 09:51 PM
I have a couple Cisco WS-C3750G-24T with 16MB flash memory.
Using IOS c3750-ipservices-mz.122-50.SE5.bin
Can't get ssh to work and think it is because of my IOS version.
What is the latest IOS version I can use for my switches that support SSH? I need to use the "ipservices" to support VRF lite.
Solved! Go to Solution.
12-10-2014 03:23 PM
You are using an image "without crypto". The image name misses the "k9". When you use one that has crypto, you can enable SSH. The recommended version is 12.2.55-SE9. All the images run with 16MB Flash.
For enabling SSH, here are some recommendations.
12-10-2014 03:23 PM
12-10-2014 03:38 PM
Ok thank you Karsten.
Will download and test it.
