2960S management int problem
vince.steiner
I have a stack of 2 2960S switches that are dedicated for the storage net, only between SAN and blade system.
I have configured fastethernet0 (management interface) for static ip 192.168.163.25 which is then connected to my core data switch, so i can manage the storage switch.
So here is the issue: if there is nothing connected to that stack at all, except the management int the switch pings and i can telnet to it.
However, if i boot the stack with all storage network uplinks and downlinks connected the management int does not ping and i have no access to the switch. As soon as i unplug the last cable, the management interface starts to ping and i can telnet in. Then i can plug all the cables and everything works fine, until i reboot the switch again.
Anybody have any ideas whats going on?
I can paste the config if needed.
7 Replies 7
Leo Laohoo
The management port of a 2960S, like the 3560E and 3750E, is for Out of Band Management (OoBM) and not used for data traffic.
I understand that, and do not want to use it as a data carrying port.
All i want to do it to use it for telnet, mgmt, but i can't because it doesn't ping after the switch boots up if i have the rest of the data cables plugged it.
Below is the config:
! Last configuration change at 09:51:19 Central Tue Jun 1 2010
! NVRAM config last updated at 10:22:06 Central Tue Jun 1 2010
version 12.2
no service pad
hostname BEP-2960-SAN1
boot-start-marker
boot-end-marker
enable secret
enable password
no aaa new-model
clock timezone CST -6
clock summer-time Central recurring
switch 1 provision ws-c2960s-24td-l
switch 2 provision ws-c2960s-24td-l
authentication mac-move permit
ip subnet-zero
no ip source-route
no ip gratuitous-arps
ip domain-list
ip domain-list
ip domain-name
vtp mode transparent
spanning-tree mode pvst
spanning-tree etherchannel guard misconfig
vlan internal allocation policy ascending
vlan 10
name Storage
vlan 11
name VMotion
interface Port-channel1
description Etherchannel to ESXi PROD1
switchport trunk allowed vlan 10,11
switchport mode trunk
switchport nonegotiate
flowcontrol receive desired
interface Port-channel2
description Etherchannel to ESXi PROD2
interface FastEthernet0
description Management
ip address 192.168.163.25 255.255.255.0
interface GigabitEthernet1/0/1
description Connection to ESXi PROD1
speed 1000
duplex full
spanning-tree portfast trunk
channel-group 1 mode on
interface GigabitEthernet1/0/2
description Connection to ESXi PROD2
speed 1000
duplex full
channel-group 2 mode on
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/24
description Connection to BEP-FAS-02 1G
switchport access vlan 10
switchport mode access
interface GigabitEthernet1/0/25
shutdown
interface GigabitEthernet1/0/26
shutdown
interface TenGigabitEthernet1/0/1
description Connection to BEP-FAS-01 10G
interface TenGigabitEthernet1/0/2
interface GigabitEthernet2/0/1
speed 1000
duplex full
interface GigabitEthernet2/0/2
speed 1000
duplex full
interface GigabitEthernet2/0/3
interface GigabitEthernet2/0/24
description Connection to BEP-FAS-01 1G
interface GigabitEthernet2/0/25
interface GigabitEthernet2/0/26
interface TenGigabitEthernet2/0/1
description Connection to BEP-FAS-02 10G
interface TenGigabitEthernet2/0/2
interface Vlan1
no ip address
shutdown
interface Vlan10
description Storage
ip address 192.168.10.1 255.255.255.0
interface Vlan11
description VMotion
ip address 192.168.11.1 255.255.255.0
ip http server
ip http secure-server
ip sla enable reaction-alerts
snmp-server community read RO
snmp-server community write RW
ntp clock-period 22518825
ntp server 192.168.168.2 key 0 prefer
end
any ideas?
Have you tried giving a client an IP address on the same subnet as 192.168.163.0/24 and then connecting directly to the OoBM port?
I did today and it worked, i can also connect to this mgmt inf if i plug my laptop directly to the same switch where i plug the mgmt connection to 2960s. However, if im on a different switch i can not ping it, access it, but i can any other device on the same net, switch.
The Management port is not a routed port.  It's not even a switch port.  It's purely for management/OoBM.  You can't connect F0 into another switch's switchport and hope to be able to access to it because it can't.
Philip DG
I see this question was never answered, and I've never seen a satisfactory answer although it's a very useful feature if you can get it to work.
Well today I finally got my switch management ports working with AAA/TACACS+ and vty ACLs
The actual problem which needs to be solved is getting the management port to use a gateway - a static IP is only useful if your management station is on the same segment, so that's quite limited.
The problem with DHCP is that the basic config can have strange behaviour - for instance in my environment I could get an IP and a gateway in a standard lease, but I couldn't initially get it to pick up a fixed IP in a reservation.
My DHCP server was recording a 48-digit hex string in the mac address field - which turned out to be a hex dump of the default Client-ID, one of the various optional parameters in the "ip address dhcp ..." interface command:
Switch#sh dhcp lease
Temp IP addr: 192.168.25.99  for peer on Interface: FastEthernet0
Temp  sub net mask: 255.255.255.0
   DHCP Lease server: 192.168.4.6, state: 5 Bound
   DHCP transaction id: 1037
   Lease: 604800 secs,  Renewal: 302400 secs,  Rebind: 529200 secs
Temp default-gateway addr: 192.168.25.1
   Next timer fires after: 3d11h
   Retry count: 0   Client-ID: cisco-5067.aeff.b739-Fa0
   Client-ID hex dump: 636973636F2D353036372E616566662E
                       623733392D466130
   Hostname: Switch
Once I configured my management port like this:
 ip address dhcp client-id FastEthernet0 hostname Switch
 no routing dynamic
...I was able to use the interface mac address to create a DHCP reservation that registered properly.
In order to get my AAA/TACACS+ working, I provided the following:
ip tacacs source-interface FastEthernet0
And now it works just like it used to on an SVI!
Hope that helps someone :)
