layer 2 issue
Silviu Lavric
Community Member
I have a frame with dest mac A getting to gateway which has a mac of B. How is that possible. Mac A is the mac of a device present on LAN. Question is how does the frame get to gateway using a different dest mac than the gateway's mac.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
It's a unicast MAC?  If so, could it have been unicast flooded?  Or, SPAN isn't configured, is it?
It is Unicast. No SPAN configured. Plenty of mac room and also all macs involved are correctly in mac table of the switch (N6k) with corresponding interfaces. IG bit and LG bit both 0. What else can I check ?
Is MAC A a directly connected device to the same switch? If no, what is the topology?
ajaskowiec
Community Member
Could it be that there is a standby ip configured, at example HSRP or VRRP protocol?
In this case the destination MAC to the Gateway would be a virtual MAC of the protocol and not the Interface MAC of the Gateway.
