Layer 2 Loop in Branch Network
hi all,
In my branch office , there is a layer 2 going on. Only two vlans exists for Data (vlan 10) and Management (Vlan 20).
My branch LAN topology look like following:
Cisco Router (fa0/0.10) ---> SW 1 (Trunk - gi 0/2)
                                                       (Trunk - gi 0/1) ----> SW 2 (Trunk - gi 0/1)
I did the following configuration to all access ports in all switches.
Access Port Config :
switchport port-security maximum 2
spanning-tree portfast
spanning-tree bpdufilter enable
There is no any security violations and still problem prevails. How do I resolve this issue ?
joe19366
Level 6
Level 6
Hi there,
Sounds like you have a device connected to the network that is fwd traffic up and down a single port, and or a cable from your cisco switch back to itself.
first, NEVER run "spanning-tree bpdufilter enable" when you have a loop. your likely PREVENTING STP from doing its job - and finding out redundant paths to root and staying fwd when it should block.
spanning-tree bpdufilter enable is like turning off spanning-tree in many cases. the ONLY time you should EVER use that command is when connecting to a device YOU DO NOT control that will have an error if it hears a bpdu.
So, once you remove that command from all ports if you STILL have a loop, i recommend enabling BPDUGUARD on each port which you some how missed. BPDU GUARD can be enabled on ANY switchport that is not a link to another switch in your topology. this will disable any interface that is looped back to your own switch either directly with a single cable or through a switch or device in your infrastructure.
let us know...
thanks,
Joe
#19366
joe19366
Level 6
Level 6
Hi there,
let us know...
thanks,
Joe
#19366
Thanks Joe for your support.
