Layer 2 Loop + portfast enabled with spanning-tree portfast edge bpduguard default
Steph1963
Hi to all,
1) Layer 2 loop
I am presently studying for my SWITCH exam and the book is talking about layer 2 loops withtout really giving some details about  it.
Just like to know if packets will start to loop on the following network when the Host A or Host B start to send packet with MAC destination address that are unknown to the switches MAC addres tables or when either Host A or B sends packet to the layer 2 broadcast address (ex. ARP packet). Can I assume that the layer 2 packet will not loop if their destination address is known by the layer 2 switches.
2) BPDU guard
I would like to know if the global command spanning-tree portfast edge bpduguard default enables portfast by default on all non-trunking interfaces (interface not configured as switchport mode trunk). In other words does the following command
Switch (config)#  spanning-tree portfast edge bpduguard default
is equivalant to
Switch (config)# spanning-tree portfast default
Thanks for your help
Stephane
Peter Paluch
Hello Stephane,
To your question 1)
I am somewhat confused by the picture you have included - you are talking about switches, yet the topology as depicted in your exhibit contains routers.
If the topology consisted of routers then by definition, routers would neither forward nor flood link-layer broadcasts so no loops would occur.
If the network consisted of switches without STP running, there is indeed a possibility of a frame looping. A frame would certainly loop if its destination MAC address is unknown to switches, or if its destination MAC is a broadcast/multicast address. The reason is that all such frames are flooded through all ports except the incoming port, and would eventually reach the same switch they originally came from.
If the switching tables were already correctly populated with correct MAC addresses and outgoing ports (i.e. knowing all connected stations and pointing towards loop-free shortest paths), loops would not occur because the frame would be forwarded through a single port only, presumably on the shortest switched path towards the recipient. However, as soon as a frame towards a new so-far-unknown destination or multicast/broadcast address was received, it would again get stuck in a loop. In a switched topology where no Layer2 loop protection is activated, the apparent loop-free operation is a very volatile and unstable state.
To your question 2)
I am afraid there is no command of the form spanning-tree portfast edge bpduguard default - the "edge" keyword here is superfluous. The correct syntax should be simply spanning-tree portfast bpduguard default
In any case, the command spanning-tree portfast bpduguard default does not activate PortFast on all non-trunking interfaces. It simply activates the BPDUGuard feature on those ports which are already PortFast-enabled. How the ports came into the PortFast mode is not relevant to the command.
Writing simply spanning-tree portfast bpduguard default without using the spanning-tree portfast default would therefore enable the BPDUGuard only on those interfaces which have explicitly been configured using the spanning-tree portfast command in their interface configuration mode (note that this command has no effect on trunking interfaces, and hence the BPDUGuard would also not be activated on them as a result).
Writing both spanning-tree portfast bpduguard default and spanning-tree portfast default would make all non-trunking ports implicitly behave as PortFast ports, and exactly those ports would then be protected by the BPDUGuard feature. No spanning-tree portfast interface-level command would be necessary here.
Please feel welcome to ask further.
Best regards,
Peter
5 Replies 5
Peter Paluch
Hello Stephane,
To your question 1)
To your question 2)
Best regards,
Peter
Hi Peter,
Thanks for another great explanation
Stephane
Stephane,
Thank you for your kind words. It has been, and always will be, a pleasure.
Best regards,
Peter
Hi Peter,
I am afraid your answer to question 2 is incorrect. The command:
is supported on 6500.
See:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/stp_enha.html
Kind regards, Joel van Praag
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
joelvanpraag wrote:
Hi Peter,
See:
True in the later IOS versions.  Those that support the "edge" keyword, I believe, will accept (and convert) prior syntax.
