Showing results forĀ
Search instead forĀ
Did you mean:Ā
Layer 2 looping in network
prince.p
Hi friends
we are using  sonicwall NSA 2400 series firewall with 46 mbps leased line connection. most of the time my firewall cpu utlization gets nearly 98 percent . due to this my network is getting struck. we are using 2 cisco 2960 series switch. in this one of the switch we connected with vlan1 interface in gi0/2 and vlan2 in gi0/4 and dmz in gi0/29. when we contact firewall support,they informing that there is an looping in the network and they are suggesting us to use layer 3 switch for dmz zone or they want to connect dmz in seperate switch layer 2 switch.i need your support that will layer2 loop will occur due to DMZ interface connected in the switch  or anything else below i attached our network diagram
Reza Sharifi
Is the Firewall the gateway for all 3 vlans? If you to test this, you can use only one of the 3 links from the switch to the firewall and trunk the interface on the switch with all vlans (1, 2 and 5) and create sub-interfaces on the firewall (if possible) and put each vlan IP on a Sub-interface.  This way you don't have multiple links from the switch to the firewall (you only have 1) and this eliminate the possibility of any loop.
