Layer 2 NAT Cisco devices
pzalex
Does THE WS-C2948G-L3 switch support configuration Layer 2 NAT (l2nat)?
Is there a list of switches compatible with this configuration?
Thanks in advance.
check this guide.
https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/industrial/software/configuration/guide/b_l2_nat_ie.html
Good luck
KB
balaji.bandi
2960 Switch - is just switch, some switches have feature for the NAT, but again what version of code running on the device.
I do not remember is that works with Cat 2960 (or myself never tested)
BB
I remember somebody asking this question a while ago, as far as I recall, l2nat is only supported on the Catalyst IE2xxx. IE3x00 Rugged, IE3400 Heavy Duty, and ESS3300 Series Switches...
