layer 2 or layer 3 issue ?
tdanetsco
Hi everybody,
in order to connect a LAN to 02 redundant routers like the attached diagram, the question is when the port Gi0/1 in 2960 switch is active and Gi0/2 is blocked, all the 03 devices are reachable (respond to ping) and traffic goes through, but when port Gi0/1 is DOWN and the port Gi0/2 is active, the routers are not rechable from 2960 switch and no traffic is possible between switch and routers.
any suggestions ?
thanks.
ohassairi
Level 9
Level 9
where is the attached diagram?
Hi There
If you look a little further down the list of posts you will see a post titled "Layer 2 or Layer 3 issue, (diagram added)" which has the diagram.
Best Regards & Best Wishes for 2008 and beyond,
Michael
i really can't find the diagram!
