Layer 3 IP checksum vs Layer 2 frame checksum
Catalin Sandu
Layer 3 IP checksum - recalculated to include changes to IP header
Layer 2 frame checksum - recalculated to include changes to the Layer 2 and Layer 3 headers
Can someone explain the diffrence between this 2 processes ? When Layer 3 recalculation checksum and Layer 2 frame checksum heppen? What devices L2, L3 are involved ?
Thank you!
Peter Paluch
Hi Sandu,
On each layer, the checksum is computed or recomputed whenever a datagram is created or modified. When such a datagram is received, the checksum is verified.
When sending an IP packet, you compute the IP header checksum, insert the packet into a frame, compute the frame checksum, and send the packet along the way.
If the frame passes through Layer2 switches only, the frame checksum is verified to make sure the frame and its contents have not been damaged or altered. However, because the frame is not modified during switching, the checksum is not computed anew because it would simply yield the same value. The IP header checksum in this case is neither computed nor verified because a Layer2 switch is interested only in processing the frame itself, not its contents. It does not even look for an IP packet in the frame payload.
When this frame arrives at a router, the router's network card will again verify the frame checksum and pass the frame contents to the higher level. Here, the IP driver will kick in, handle the received packet, verify the IP header checksum, and if it is correct, the router starts routing it. After going through the routing table, it determines the next hop for this IP packet. Then, the router decrements the TTL in the IP header, and because this caused the header to be modified, the IP header checksum needs to be computed anew. The router therefore computes the new IP header checksum, inserts it into the packet header, then encapsulates the packet in a new frame, computes the new frame's checksum and sends the frame again towards the recipient.
This process repeats itself until the packet is delivered to the final destination. Remember: the checksum is verified whenever a datagram is being processed, and is recomputed when the datagram is created from scratch or deliberately modified during transit. Frames are processed by L2 and higher devices: NICs, bridges, switches, routers, firewalls, end hosts etc. IP packets are processed by L3 and higher devices: end hosts, routers, firewalls, ...
Please feel welcome to ask further.
Best regards,
Peter
great explanation
AL-ATHWARI
Peter's explanations generally are. I would add a note though to his statement "When this frame arrives at a router, the router's network card will again verify the frame checksum and pass the frame contents to the higher level." This assumes the frame checksum is okay, if not the frame would be discarded and, of course, the IP packet not checked. In theory, the IP checksum could pass, while the frame checksum does not, but if the frame is "bad" you couldn't confirm the frame was meant for you or what host sent it, etc.
Still Helpful
