Layer 3 on Catalyst Switch 2950 Series
allen.malanda_2
Does the Catalyst Switch 2950 Series supports layer 3 switching? Or, which IOS image supports layer 3 switching on the Catalyst Switch 2950 Series?
cowetacoit
2900 series are only layer 2. you would need to upgrade to a 3560 or a 3750.
garytayl
Level 3
Level 3
Catalyst 2950s are layer 2 switches therefore IOS won't make a difference. Unfortunately you will need a different switch.
Marwan ALshawi
2900s dose not support layer three capabilities but it support layer 2 to 4 intelegent such as QoS marking
and RACL and class-map based on IPs ( but no routing)
while 3500s and above support layer 2 3 4 capabilities and intelegent
good luck
please, if helpful rate
