Layer_3 Switch 3750
ahmedalnajjar
I have Layer_3 " 3750-x " , so I con't do any routing on the switch , so please if I need to Upgrade the IOS give me the preffered image that support hte routing , and Is it free or should I pay?
7 Replies 7
Reza Sharifi
when you say routing, what are you trying to do? OSPF, BGP, EIGRP, static route, etc...?
It has nothing to do with IOS version.  It all deends on your license level
Can you post sh ver?
Also
try this
config t
ip routing
WS-C3750X-24P-L this is the Switch model
I need to do Rip
post sh version
12.2(55)SE3
The reason I asked for sh ver is because it tells you what license level you currently have.
You can also get that with
sh license
Anyway, if you license level is IP Base you can run RIP.
It is not IP base , it is LAN base
