07-12-2011 09:29 AM - edited 03-07-2019 01:11 AM
if i want to connect a layer 3 (router ) to layer 2 (Switch) connection, what wikll be the config ( i would like to allow the entire 172.21.x.x range)
router - 172.21.10.1 ip address
switch - trunk mode
can you please provide me with the config
07-12-2011 09:35 AM
If you are connecting a router to a switch then there is no special configuration required at all, assuming you are not using the router to route between several VLANs. In this simple case, you configure the router with the usual configuration:
interface FastEthernet0/0
ip address 172.21.10.1 255.255.255.0
no shutdown
And you connect it to a switchport configured for access mode in the same VLAN as the remaining ports where the stations in the network 172.21.10.0/24 are connected, for example, VLAN 1 and port Fa0/24:
interface FastEthernet0/24
switchport mode access
switchport access vlan 1 ! This is the default
Alternatively, you could use a different VLAN, say, VLAN 10 for this deployment. The configuration on the router would remain exactly the same. The switchport configuration would be slightly different:
switchport access vlan 10
Note that in this case, also other ports leading to stations in the 172.21.10.0/24 network must be placed into VLAN10.
Your requirement is described a little too briefly - if this does not answer your question then please provide more information about what is your network topology and what are you trying to achieve.
Best regards,
Peter
07-12-2011 01:12 PM
Peter is correct. The only thing that I would change is the subnet mask. Assuming you wanted to allow the whole 172.21.x.x (or 172.21.0.0/16) range, using 172.21.10.1 as the gateway your config on the router would be:
ip address 172.21.10.1 255.255.0.0
no shutdown
07-12-2011 01:24 PM
Antonio,
Thanks for the update. Yes, you are correct... I have slightly ignored the OP's indicated address space.
Best regards,
Peter
07-13-2011 02:32 AM
Thanks for the replies.
this is my requirment
router ip address 172.21.100.3
I have the following vlans on my switches
switch vlan1 - 172.21.1.x
switch vlan2 - 172.21.2.x
switch vlan3 - 172.21.3.x
say if i add more and would like to allow the whole of 172.21x.x range then what would be the config ?
07-13-2011 02:46 AM
say in the above example my config is as below
router
int fas0/1
ip address 172.21.100.3 255.255.255.0
no shu
switch
int vl 1
ip address 172.21.1.1 255.255.255.0
int vl100
ip address 172.21.100.1 255.255.255.0
int fas0/1
swithport mode trunk
the above wouldnt work, would it as its diffenerent subnet (only vlan 100 would be allowed, and not vlan 1 - since same subnet)
so we need to create a sub interface on the router, isnt it ?
int fas0/1
int fas0/1.1
ip address 172.21.1.3 255.255.255.0
will the abvoe work ?
if the above works, then if i want to allow whole of 172.21.x.x range then what do i do ?
do i just create on the router
int fas0/1
ip addrss 172.21.100.3 255.255.0.0
will the abvoe work as per your explanation ?
please let me know (also the alternative of adding a default route on the router will it solve the problem ?)
07-13-2011 06:31 AM
any thoughts on the above pls ?
07-13-2011 08:06 AM
From your description, you want to route multiple subnets. There are two ways to do it.
Router on a stick configuration:
- Need to create a sub-interface for every vlan you want to route.
1. Router config:
int fa0/1
no ip address
int fa0/1.1
ip address 172.21.1.2 255.255.255.0
enacapsulation dot1q 1 native
int fa0/1.2
ip address 172.21.2.2 255.255.255.0
enacapsulation dot1q 2
int fa0/1.100
enacapsulation dot1q 100
Switch:
int fa0/24
switchport mode trunk
int vlan 1
int vlan 100
2. Routed option: This requires a L3 capable switch. What switch do you have?
Hope this helps. Here is a link whic explains router on a stick configuration.
http://www.cisco.com/en/US/tech/tk389/tk815/technologies_configuration_example09186a00800949fd.shtml
AJ
07-13-2011 08:15 AM
thanks for the reply ajasti..i understand router on stick config..my doubt is ..what will be the output of this ?
router
int fas0/1
ip address 172.21.100.3 255.255.0.0 (please note /16 subnet mask)
no shu
switch (please note /24 bit mask)
int vl 1
int vl100
int vl 2
ip address 172.21.2.1 255.255.255.0
int fas0/1
will the above work?
also if i make the trunk to a access port on the switch, should i just be able to ping from the native vlan - vlan 1 ?
please let me know
thanks
07-13-2011 05:06 PM
Will the above work?
NO. Router will send the traffic to switch but switch will drop it. ARP will also not get resolved properly. Also all packets (except in vlan1) will be dropped as invalid packets (due to presence of dot1q tag in them).
YES.
AJ.
07-14-2011 04:53 AM
but as per Anotnio and Peter's comment, they have said anything in /16 subnet should work? so i am confused now ?
07-14-2011 04:57 AM
so what will be the way to allow the whole of 172.21.x.x range ?
