layer 3 trunk interface
suthomas1
Level 6
Level 6
A 3750 switch is connected to an upstream device. Two ports from 3750 connect to one each of the upstream device, which is in HA state.
Following is the configuration currently on the 3750:-
Int vlan 101
ip address 192.168.1.1 255.255.255.252
int gi0/21
switchport access vlan 101
switchport mode trunk
int gi0/22
Multiple vlans will be traversing this link between the 3750 and the upstream devices.
The upstream device has a subinterface created with ip  192.168.1.2 tagged with vlan101.
The Ip's 192.168.1.1 & 1.2 are been used for routing the subnets located, from either of the devices.
In this case, is access vlan 101 command required on the physical interface on 3750?
Will we be able to establish ping and communication and use the ip's for routing if access vlan 101 is removed from both interface.
Thanks in advance!
If you want to allow all vlans, then just do this:
interface Gi0/22
will the ip's 192.168.1.1 & 1.2 create an arp entry in each other device and be able to ping each other?
if yes, how will it work as the ip subnet is configured under vlan 100.
Yes, as long as you have an SVI on each switch, it will work fine. The source address will be the IP address on the SVI.
Reza Sharifi
no, since the port is trunked, it is allowing all vlans.
You don't need
If you want to only allow vlan 101 in your trunk than have a look at this config:
interface Gi0/22
switchport trunk allowed vlan 101
end
Thanks, so with only the following commands,on the interface;
switchport trunk allowed vlan all
thanks.
interface Gi0/22
