Layer 7 inspection
ruliffilur
Hello
I am working with in an organisation that is in need for layer 7 inspect. We need to match protocols like online games, file sharing and any other services that uses dynamic assigned ports.
What Cisco device is able to accomplish this?
//Rulif
speculor_cisco
Hello Rulif.
I have not an answer to your question but I was curious about. So I have decided to throw again your post.
May be Cisco implements only security at Layers 2,3 and 4. It would be quite logic too.
It would be appreciated even only a confirm about this inability.
Thanks.
sean_evershed
Level 7
Level 7
You can use NBAR in combination with a class map to do drop this type of traffic. See the attached link for an example based on blocking Skype.
https://supportforums.cisco.com/docs/DOC-5818
See also a Q&A reference guide for NBAR
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6558/ps6612/ps6653/prod_qas09186a00800a3ded_ps6616_Products_Q_and_A_Item.html
Please remember to rate all posts that are helpful
