Layer3-Switch
AurMuc18
Community Member
Problem: I want to configure a port in my L3 switch as no switchport, i.e. as a routed port. When I specify the command no switchport, it says that command rejected, not allowed in this interface. The instructor has said that there the license must be changed.
How does that work?
5 Replies 5
ammahend
Enable ‘ip routing’ globally then try.
Share output of show license details and show inventory
-hope this helps-
M02@rt37
Hello @AurMuc18
I assume that your Switch has got LAN Base license...
Please check with #show licence or #show version command
  • LAN Base: Basic Layer 2 features.
  • IP Base: Adds Layer 3 static routing and limited dynamic routing.
  • IP Services: Full Layer 3 functionality, including advanced routing protocols like OSPF, BGP, and EIGRP.
Best regards
The issue you're facing likely stems from the licensing applied to your Layer 3 switch. Certain models, especially those with a base LAN or Layer 2 license, do not support advanced Layer 3 features like configuring a port as a routed port using the no switchport command. When the system rejects this command, it’s a clear indication that the current license doesn’t permit such functionality.
To address this, you’ll need to upgrade the license to one that supports Layer 3 features, such as the IP Base or IP Services license, depending on your switch model. You can confirm your current license type by using the show license command in privileged mode. Once you obtain the appropriate license from Cisco or your vendor, activate it through the license activation process and reboot the switch. After the upgrade, the no switchport command should work as expected, allowing you to configure the port as a routed port.
@AurMuc18
 Not all switch will support that despite the license. Which switch model do you have?
Joseph W. Doherty
Do other ports accept that command?
If so, is the rejecting port in a different module or "bank" (e.g. 1/1/1 vs. 1/2/1 or 2/1/1)?
