04-19-2016 06:26 AM - edited 03-08-2019 05:24 AM
Why R1 can go on internet but not R2 ?
R1 and R2 created adjacency with OSPF. can ping each other.
R1 can ping 8.8.8.8 but R2 can t.
Solved! Go to Solution.
04-19-2016 01:07 PM
We still have minimal information on R2 - that's where the routing table is "needed" for diagnostics.
Presumably the NAT function is done on the Verizon cable router. IT presumably knows the way back to 192.168.1.x addresses, but no other - and it will NOT know how to get back to 192.168.3.0. Even if you ping 192.168.1.1 from R2, you won't get a response ? This is because the packet makes it TO the verizon router; but it doesn't know how/where to return the packet to anything internal other than 192.168.1.x, unless it has additional static routes in place to get the packet back to R1 (who DOES know how to get to 192.168.3.x addresses).
So, you'll either have to modify the verizon to get that to work; or to NAT on R1's interface to R2 that they look (to Verizon) like they are coming from additional 192.168.1.x ports using one of the NAT / PAT schemes.
04-19-2016 08:18 AM
Minimal information here. Config listing from R1 and R2 would help.
However, on R2, what all do you see on "sh ip ro" ? Do you have all the routes you should see from R1; and do you have a default route from R2 to R1 ?
04-19-2016 09:16 AM
Im currently trying to access internet with a cisco lab and a verizon router, but Its look like i'm missing something.
Will try to be clear in my description of the network.
Hardware : 2 routers cisco 1760. R1 and R2 link together via serial 0/0.(10.1.1.0 /30) (wic card t1) and a cable verizon router quantum g1100.
-verizon cable router(192.168.1.1) is connected with R1 FA0/0 192.168.1.200
-on R1 i added IP route 0.0.0.0 0.0.0.0 192.168.1.1
-from R1 I can ping google 8.8.8.8.
The problem occur when i try to ping the verizon router (192.168.1.1) from R2 (connected thru serial 0/0 with R1).
-from R2 i can ping the address 192.168.1.200 (R1 FA0/0) but can't reach the verizon router.
its looks like im block at R1 FA0/0.
OSPF is running on both R1 and R2.
Here is the copy of the routing table on R1
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 12/14/16 ms
R1#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is 192.168.1.1 to network 0.0.0.0
1.0.0.0/32 is subnetted, 1 subnets
C 1.1.1.1 is directly connected, Loopback0
2.0.0.0/32 is subnetted, 1 subnets
O 2.2.2.2 [110/65] via 10.1.1.2, 00:10:23, Serial0/0
10.0.0.0/30 is subnetted, 1 subnets
C 10.1.1.0 is directly connected, Serial0/0
C 192.168.1.0/24 is directly connected, FastEthernet0/0
S 192.168.3.0/24 [1/0] via 10.1.1.2
S* 0.0.0.0/0 [1/0] via 192.168.1.1
04-19-2016 01:07 PM
04-19-2016 01:35 PM
Thanks for your help
Here his both ip route table for R1 and R2.
will try the NAT/PAT shemes on R1.
R1#ping 8.8.8.8
Success rate is 100 percent (5/5), round-trip min/avg/max = 12/13/16 ms
R1#sh ip route
O 2.2.2.2 [110/65] via 10.1.1.2, 00:19:50, Serial0/0
3.0.0.0/32 is subnetted, 1 subnets
O 3.3.3.3 [110/129] via 10.1.1.2, 00:19:50, Serial0/0
10.0.0.0/30 is subnetted, 2 subnets
O 10.1.1.4 [110/128] via 10.1.1.2, 00:19:50, Serial0/0
C* 192.168.1.0/24 is directly connected, FastEthernet0/0
S 192.168.3.0/24 is directly connected, Serial0/0
R2#sh ip route
Gateway of last resort is 10.1.1.1 to network 0.0.0.0
O 1.1.1.1 [110/65] via 10.1.1.1, 00:22:11, Serial0/0
C 2.2.2.2 is directly connected, Loopback0
O 3.3.3.3 [110/65] via 10.1.1.6, 00:22:11, Serial1/0
C 10.1.1.4 is directly connected, Serial1/0
O 192.168.1.0/24 [110/65] via 10.1.1.1, 00:11:33, Serial0/0
C 192.168.3.0/24 is directly connected, FastEthernet0/0
O*E2 0.0.0.0/0 [110/1] via 10.1.1.1, 00:09:05, Serial0/0
04-19-2016 07:25 PM
thanks pwwiddicombe.
Your idea about NAT/PAT was good.
First i add a static NAT on R1 for 192.168.3.0 to see and I was able to ping google but i couldn't ping anymore from R1.
then with an access-list permit any on R1
R1(config)#access-list 1 permit any
R1(config)#ip nat inside source list 1 int fa0/0 overload
its works fine from any networks.
I guess with all the command i have tried and deleted the config is horrible and not optimal but it made me understand some good things.
thanks again.
