License smart on Cat9300
JoeNaRuTa
Dear All,
Now I've implemented Cat9300 in my network but I've never done License smart registration process.
#sh license all
Smart Licensing Status
Smart Licensing is ENABLED
Registration:
Status: UNREGISTERED
Export-Controlled Functionality: NOT ALLOWED
License Authorization:
Status: EVAL MODE
Evaluation Period Remaining: 40 days, 10 hours, 48 minutes, 33 seconds
Export Authorization Key:
Features Authorized:
<none>
Utility:
Status: DISABLED
Data Privacy:
Sending Hostname: yes
Callhome hostname privacy: DISABLED
Smart Licensing hostname privacy: DISABLED
Version privacy: DISABLED
Transport:
Type: Callhome
License Usage
(C9300-48 DNA Advantage):
Description:
Count: 2
Version: 1.0
Status: EVAL MODE
Export status: NOT RESTRICTED
(C9300-48 Network Advantage):
Description:
Count: 2
Version: 1.0
Status: EVAL MODE
Product Information
UDI: PID:C9300-48T,SN:FOCXXXXX
HA UDI List:
Active:PID:C9300-48T,SN:
Standby:PID:C9300-48T,SN:
Agent Version
Smart Agent for Licensing: 4.8.5.1_rel/8
Reservation Info
License reservation: DISABLED
My questions
1. What will be happen on my device after license expired?
2. What I can do on my device after license expired?
BRs
Joe,
#catalyst #9300 #smartlicense
Francesco Molino
After 40 days you'll lose all features related to advantage level license (e.g. bgp routing...).
Check out this link to see what's related to advantage license:
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9300-series-switches/nb-06-cat9300-ser-data-sheet-cte-en.html#Licensing
You need to register your switch to your smart account portal.
Do you have a smart account? Normally when you purchased these switches, your licenses you bought should have been deposited into this account (you should have bought essential or advantage licenses).
This link shows how to register your switch with your smart account portal:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9300/software/release/16-9/configuration_guide/sys_mgmt/b_169_sys_mgmt_9300_cg/configuring_smart_licensing.html#id_90487
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Michael Muenz
Level 5
Level 5
Any updates on this? I have one stack overdue long time and still running and a second one which is now 80 days until EVAL ends.
Michael Please rate all helpful posts
