license upgrade in 2900 for securityk9 feature
r.kukreja
Beginner
Beginner
hi,
i have 2921 router with base license . i want to upgrade to it to security k9 feature or want to enable it. i have license file with product activation key. how should i do it. if any body have screen shot file please help
regards
rajat
kmccourt
Beginner
Beginner
The instructions are at
http://www.cisco.com/en/US/docs/routers/access/sw_activation/SA_on_ISR.html#wp1097551
For example, if you put the license file on to a USB stick, the command will be along the lines of:
license install usbflash1:license-file-name.xml
Recognize Your Peers
