InterVlan Routing on Cisco 881
genseb13011
I'd like to set Inter-Vlan Routing on my Cisco 881.
Vlan 2: 192.168.0.0 /25
Vlan 3 : 192.168.0.128 /26
Vlan 4: 192.168.0.192 /26
This is my running conf:
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
switchport mode trunk
interface FastEthernet4
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
no ip address
interface Vlan2
ip address 192.168.0.1 255.255.255.128
interface Vlan3
ip address 192.168.0.129 255.255.255.192
interface Vlan4
ip address 192.168.0.193 255.255.255.192
When I plug a cable on the fa3, the Vlan 2, 3, 4 are up.
I can ping each Vlan IP address from the router but when I try to ping the router from a PC connected to the Fa3 interface, it doesn't work.
Thanks for your answers
Santosh Kolte
for PC.....I think u should use acess port of any vlan u created & give default gateway address of that vlan interface
no need to make it Trunk.....
8 Replies 8
Leo Laohoo
What is the IP Address of the PC?
PC firewall enabled?
I've tried with 3 different address:
192.168.0.194 / 255.255.255.192 trying to ping 192.168.0.193
192.168.0.130 / 255.255.255.192 trying to ping 192.168.0.129
192.168.0.2 / 255.255.255.128 trying to ping 192.168.0.1
I also disabled the PC firewall because i though it could be the problem but it wasn't.
Could you use "ip routing" command on Router?
You connected the PC to an 802.1Q Trunk port?
interface Vlan2
If you configure your PC to, say 192.168.0.2/25 and you assign the port to VLAN 2 (switchport access vlan 2), can you ping 192.168.0.1?
Abzal
Level 7
Level 7
The problem might be that you're connecting PC to trunk port with default native VLAN 1. But you don't have VLAN 1 ip address assigned. Try to change from trunk to access port like VLAN 2/3/4 and IP address from subnet.
Hope it will help
Best regards,
Abzal
Anup Sasikumar
I think you shouldnt be connecting a PC to trunk. It should be either in VLAN 2 3 or 4 and the default gateway should be set as the corresponding interface VLAN IP for inter vlan routing to work.
Anup
Anup
Santosh Kolte
genseb13011
When I assign vlan 2 to fa2 and vlan 3 to fa1 and I try to ping it works.
So the interVlan routing works.
Thanks for all your answers
