Licensing on WS-C3750-24PS-S vs WS-C3750-24PS-E
Sam Brynes
I did some research and it looks like the only thing different between WS-C3750-24PS-S and WS-C3750-24PS-E is that the WS-C3750-24PS-E version runs a CIsco IOS with the the " IP Services software feature set (IPS)", and the other one runs a Cisco IOS with only the "IP Base software feature set (IPB)".
I know that in Cisco IOS 15, there needs to be an appropriate license installed on the switch to activate the correct feature set.
My question is if I run Cisco IOS 12.x, can I upgrade a unit with a Cisco IOS "IP Base software feature set (IPB)" with a Cisco IOS "IP Services software feature set (IPS)" by just switching out the IOS image?
I am thinking of purchasing a used Cisco 3750 from eBay, but I really want it to have all the IPv6 features enabled and ready for use without breaking the bank.
Bilal Nawaz
Yes you can. I believe you can only get to 12.X with those switches anyway (3750-24PS). e.g. c3750-ipservicesk9-mz.122-55.SE9.bin would be your best image and latest image.
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
The original generation 3560/3750 series have "paper" licenses.  You can either order them, originally, with the advanced license, the "-E" suffix, or you can order them with the base license, the "-S" suffix, and later, if desired, "upgrade" them by purchasing a paper license.
Technically, the device has no license management, so it will run either the base or advanced IOS; whatever is installed.
As the original generation devices are EoS, I don't believe advanced "paper" licenses are still available.  If not, would be unable to legally run an advanced IOS image on a device that doesn't already have the advanced license.
Leo Laohoo
I agree with Bilal.
If you have the all-FastEthernet model of the 3750, then it means that the switch only has 16 mb flash.  This also means that the "highest" IOS you can use is the 12.2(55)SE-train one.  You will not be able to use any higher IOS due to the limitation of the flash memory.
