10-10-2014 07:50 AM - edited 03-07-2019 09:03 PM
We are going to be moving our Datacenter to a Colo facility soon. We currently have our datacenter in a different building from our main staff connected by fiber across 2 gig interfaces in a port channel.
I would like to limit the speed of this port channel to 10mb to simulate the WAN link at the Colo as a test. When I run the Speed ? command on that po interface on the Nexus my lowest choice is 100mb. Is there a way to crank this down to 10mb just for testing purposes?
Thank you
10-10-2014 04:23 PM
Nexus wasn't design to run 10 Mbps.
If Nexus support Policy Shaping, then you might want to try using this method.
10-16-2014 01:51 AM
I think the only way you can do this is using media converter (for ex: OV221T) which converts fiber media to fastEthernet on both side of the link then do your test on 10/100 ports on your nexus.
In this case, you can easily set your desired 10Mbps speed
10-16-2014 05:15 AM
I ended up contacting support to see what could be done. This is the response.
Here are the commands you may use to limit traffic ingressing on that port to 10 mbps or the rate you want to.
ip access-list limit-acl
10 permit ip any any
class-map type qos match-all limit-qos-cmap
match access-group name limit-acl
policy-map type qos limit-qos-pmap
class limit-qos-cmap
set qos-group 2
police cir 10 mbps bc 250 ms
interface <>
service-policy type qos input limit-qos-pmap
>> Nexus platform doesn’t support all the qos features for it being majorly a datacenter switch and therefore you could only limit traffic inbound to that port but outbound traffic policing isn’t really supported. This should limit traffic in one side atleast.
08-07-2017 12:27 AM
when we try to configure that on our 9508, we get this error:
Unable to perform the action due to incompatibility: Module 4 returned status "TCAM region is not configured. Please configure TCAM region and retry the command"
Is there any solution?
