help me please
jarode fox
Community Member
I have an ADSL fiber optic line coming from my ISP, I do not want to use the router of my ISP, then what router cisco then I use please? Knowing that there will be 3 L2 switch cisco after, that I want to connect to router by fiber optic
thank you
15 Replies 15
Georg Pauwen
the models below all have SFP ports for fiber connections:
C896VAG-LTE ISR
C897VAG-LTE ISR
C898EAG-LTE ISR
C899G-LTE ISR
They are not cheap though, prices are in the $1000 to $1500 range...
It's an internet fiber optic line from ISP
Sorry
to avoid confusion: what type/brand is the ISP router/modem you have at the moment ?
Alcatel-Lucent (modèle G-240W-A)
https://networks.nokia.com/products/7368-isam-ont-g-240w-b ?
I do not want to use my alcatel router but a professional cisco router
I believe in your case you would need a modem and a cisco router (your current router provides the functionality of both).  The router you would need must contain an NM that will terminate the connection to the modem.  So the NM will need modem functionality.  I'm sure they exist and I'm sure others have done it.
Can you tell me who your provider is?  I think that's the best way to get started to find you a reasonably priced legacy router and modem that will work.
You may be able to ask your provider for a modem only solution to satisfy one piece of the puzzle. Below are the two options you might have.  I beleive you'll be able to find the hardware to satisfy option #1 and less likely to find it for option #2.
my ISP is MAROC TELECOM from morocco
I would suggest running a search on that provider along with the terms "cisco router".  I'm sure someone has set this up before and will be able to offer guidance.  It will save us the headaches of mixing and matching a modem and a router hoping it will work with your provider.
I will follow your advice and thank you very much
This is a fiber to the home (FTTH) modem / router although I don't see the fiber termination point on the graphic in the link.  I'm going out on a limb and guessing this is Google Fiber or equivalent.
You may need a modem before attaching your own router unless there's a network module available from Cisco that will allow you to terminate it in a cisco router. That module would need the modem capabilities.
GPON uplink
• 1490 nm wavelength downstream,
1310 nm wavelength upstream
• 2.488 Gb/s line rate downstream,
1.244 Gb/s line rate upstream
• GPON Encapsulation Method (GEM) mode
support for IP/Ethernet service traffic
support
• ITU-T G.984.3-compliant dynamic
bandwidth reporting
• ITU-T G.984.3-compliant Advanced
Encryption System (AES) in downstream
• ITU-T G.984.3-compliant FEC
• ITU-T G.988 Appendix 1 and Appendix 2
ONT Management Control Interface (OMCI)
• Remote software image download
• Small form factor (SFF) type laser, SC/APC
connector
According to manual - page 57 - fiber optic port is on the right side, but it is covered.
Who is your provider?
Comcast, Verizon, Google Fiber, other?
Typically it would be coax into your modem from the poll and ethernet out to your LAN.  I'm not sure what Google would provide though if it is in fact Google.
Predrag Jovic
Level 8
Level 8
Is something like that exist?
