01-11-2020 01:06 AM
Hi Dear friend my Question is
How limite VLAN TX OR RX (bandwidth) on switch layer 2 cisco For example 2960
I used Srr queue But this is not work !
Please Help me
Solved! Go to Solution.
01-11-2020 01:34 AM
I think QoS on the 2960 is only supported on physical ports, not at the VLAN level...
Either way, how did you configure the SRR ? Below is an example where you would limit the bandwidth to 10 percent of the physical bandwidth:
interface GigabitEthernet1/0/3
srr-queue bandwidth limit 10
01-11-2020 01:34 AM
