Limiting bandwidth on a switch interface
tyler.perkey
Hi all,
I work for an MSP and we have some customers in our DC that we sell bandwidth too.  We have a 1GB pipe coming into our outside switch and a customer in port 3 that we need to restrict to 300mpbs up/down.  Our outside switch is a 3750G, we are trying to determine the best way to accomplish this task.  Right now we have a policer policy on the input of the port, this config works in our lab, but we don't see any stats in the lab switch or in production switch.  Below is our config:
ip access-list extended ANY_IP
permit ip any any
class-map match-all ANY
match access-group name ANY_IP
policy-map Policer_100M
description 100Megs Bandwidth
class ANY
police 100000000 8000 exceed-action drop
interface GigabitEthernet1/0/5
description Customer
switchport access vlan 9
ip access-group ANY_IP in
spanning-tree portfast
service-policy input Policer_100M
When I look at the policy stats I have nothing:
Service-policy input: Policer_100M
Class-map: ANY (match-all)
0 packets, 0 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: access-group name ANY_IP
Class-map: class-default (match-any)
0 packets, 0 bytes
Match: any
0 packets, 0 bytes
5 minute rate 0 bps
Joseph W. Doherty
Your policy is likely working as intended, but 3750Gs, especially if running older IOS versions, don't always reflect stats in the higher level commands. When they don't, you can sometimes see the stats in the lower level hardware commands.
