PBR with ECMP in Catalyst 3xxx and 93xx switches
RameshPVN8915
I am trying to enable PBR with ECMP (using recursive next hop) on Catalyst 9300 switches and I am getting a syslog that this feature is not supported.
Sep 13 21:34:05.528: %FMANRP_PBR-3-UNSUPPORTED_RMAP: Route-map pbr1 has unsupported options for Policy-Based Routing. It has been removed from the interface, if applied.
Can I know which products/software release supports this feature ?
I am tying to do PBR from SVI, onto L3 Uplinks. All the next hops are all resolved.
I have a route for some dummy IP - that I gave as recursive next-hop and configured 2 paths for this dummy route - using next-hops of directly connected uplinks.
I can give the config - but please let me know why its not supported.
--Ramesh
7 Replies 7
Reza Sharifi
Usually for advanced feature like PBR, you need and advance license?
What is your license level?  "sh ver" should show you that.
Technology Package License Information:
Technology-package Technology-package
Current Type Next reboot
network-advantage Permanent network-advantage
dna-advantage Subscription dna-advantage
Can I know which products support PBR with ECMP in the catalyst family and with what license ?
The recursive nexthop way of achieving PBR ECMP - I am not able to configure such route-maps as the config is being rejected saying its not supported.
Have a look at table 13 in this link. Not sure about PBR/ ECMP but just PBR is supported with Network Essential.
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9300-series-switches/nb-06-cat9300-ser-data-sheet-cte-en.html#Licensing
Thanks for the response. Yes PBR works for me fine.
Issue is only with PBR+ECMP using recursive nexthop.
Hello Ramesh,
see the following document
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/XE3-6-0E/15-22E/configuration/guide/xe-360-config/pbroute.pdf
set ip next-hop recursive should be supported on Catalyst 4500 as reported in the link above and I guess on Catalyst 6500, 6800.
The set ip next-hop recursive may require  a TCAM able to support it.
It is not  so easy as normal PBR, multiple pointers to the possible next-hops need to be installed in TCAM in the FIB, and then CEF load balancing must choice one of them for each flow ( given a source IP and a destination IP.
address that match the route-map block/clause).
I'm afraid Access switches are not expected to support a feature like this.
Hope to help
Giuseppe
Thanks for the response. Match criteria would need a TCAM and not the "recursive-nh" part. Ability of the TCAM result to pass a single nexthop or a ECMP pointer could be limiting the access switches. The Recursive nexthop to ECMP pointer anyway is a software concept and ASIC capability is only about being able to drive a the result of Single-NH or ECMP-PTR. Looks like even the Catalyst 93xx ASICs do not support it? NXOS does support it though (even the cheapest boxes).
