limiting bandwidth on cisco switches
khiladi0003
Hello
I am new at networking and recently at an interview I was asked how to limit bandwidth (let's say to 1 Mbps) on Cisco 3560 and 3750 switches on a port level basis (for each PC that is connected to a port).
What are the different ways and also the easiest way to do it.
Julio E. Moisa
Basically you can use MQC (Modular Quality of Service Command) to match certain type of traffic or networks and apply a policy, now in order to limit bandwidth you could Police or Shape, a different between them is Shape can be applied to Outbound direction only. These methods are pointing to the same target but they work on different ways.
Please check this link:
http://packetlife.net/blog/2008/jul/30/policing-versus-shaping/
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Julio E. Moisa
Hope it is useful
Hello
SRR-queue bandwidth port port basis can acomplish this, which can be either in a Share or shape mode or both.
Example:
int x/x
srr-queue bandwidth share 1 50 20 29 -  Share the bw on a % of the value specified
srr-queue bandwidth shape 20 0 0 0  -  Overrides share mode, so in this case queue 1(default queue)in share mode is render ineffective so this can be set to a very low value , but the remaining 3 queues would be used on a shared based regarding their % value.
So the above reads
Shape 20 queue 1 =  1/20th of the interface ( 100mb link that's 5mb)
Shared queue 2/3/4 = 95 mb remaining  ratio: 5:2:3
res
Paul
Kind Regards
Paul
