Catalyst 3750-24TS /Catalyst 3750-24PS
samith_me
Any One knows, How to download  Catalyst 3750-24PS/Catalyst 3750-24TS switches version 15.0 IOS.
@samith_me wrote:
can I install 3750G switch 15.0 IOS to 3750PS-L switch ?
Not even remotely possible.  3750 (FastEthernet access ports) have only 16mb flash.  IOS version 12.2(58)SE and later require flash memory to be 24 mb flash.  If the plain 3750G is added to a stack that is running a different IOS versin, the 3750G will not join the stack.
8 Replies 8
Leo Laohoo
15.X IOS is not compatible with 3750 with FastEthernet ports.
As per my knowledge 15.0 support
If the switch only has 16MB of flash then IOS 15 just won't fit in there.  You could experiment with booting from TFTP though...
You can check what your switch supports on this link , it has each model and when you click in you can see what ios software it can support
https://software.cisco.com/download/navigator.html?mdfid=277987617
Thanks for taking the time to rate our posts.
Leo Laohoo
I have another solution.
Read the Release Notes for the IOS version currently installed in the 3750-24PS. The Release Notes will state which specific hardware/model is compatible. See if the 3750X is compatible. The "lowest" IOS version some 3750X can run is 12.2(55)SE train. If this is so, then upgrade the 3750-24PS to the latest 12.2(55)SE train
