12-04-2009 10:02 PM - edited 03-06-2019 08:50 AM
Hi Dears,
I am Saravanan, working as a network engineer. In one of my customer have 4Mbps Internet, They have 4 vlan groups. Now current setup is Sharing the 4 mbps Internet to every body, but they want to limit the bandwidth in vlan groupwise.
Consider Vlan 1 in 192.168.10.0 /24
Vlan 2 in 192.168.15.0/24
Vlan 3 in 192.168.20.0/24
Vlan 4 in 192.168.21.0/25.
I want to give more bandwidth in vlan 4, around 2mbps, remaining 2mbps should share to all.
I have cisco 4503 as L3 switch and i have MPLs connection to connect to another location.
This limitation of bandwidth should occur only in using of Internet not for LAN or Intranet.
202.X.X.233 202.X.X.234 192.168.10.2 10.4 192.168.10.1
ISP link -------------> Firewall (Checkpoint) ----------> Proxy server -----------> Cisco 4503 -------> distribute in to 4 vlan.
please give a valuable reply.
Thanks for you spend your valuable time.
12-04-2009 10:57 PM
Hi Saravanan,
Bandwidth limitation can be usig qos,Check out the below link for configuring qos as per you requirement.
Hope this will help you to some extent !!
Ganesh.H
12-05-2009 10:23 AM
Very very thanks mr. Ganesh.
Any other related document is there regarding the issue.
12-06-2009 05:01 AM
OK try with this link it will help yout to configure and understand how to configure the qos in your network.
http://www.cisco.com/en/US/docs/ios/12_2sb/feature/guide/vlntgqos.html
Ganesh.H
